Im F*CKING stupid!
Old 07-20-2009, 10:23 PM
Hotroddin's Avatar
Default Im F*CKING stupid!
so, i did my clutch swap on saturday and had not a single problem. but when i filled my trans up and pulled my car off the lift i noticed a small puddle, so i put it back up in the air and noticed i was seaping fluid from a hairline crack below the drain plug, i overtightened it because i put it in with my impact i can't believe i was so dumb. so i covered it with some off brand jb weld while it was still seeping and now it still slowly seeps. i lifted the car again today and pulled the fill plug and i was still full enough on fluid that it would dribble out of the fill plug, but obviously i need to fix it. soo, next weekend im going to drain the fluid and use some alumaweld junk from the local welding shop. so will this hold? or do i need to find a new tailshaft housing? and how hard it is to swap just the rear housing? any info is greatly appriciated. thanks
Old 07-20-2009, 10:35 PM
2000Z28M6's Avatar
dude....my buddy is an ******* for doing this on my car too. I told him never use the impact when assembling!
he over tightened a bolt on the bell housing, luckily this can be heli coiled.
I wish you luck, maybe a good aluminum welder?
Old 07-21-2009, 12:50 AM
Cthulu's Avatar
Your problems make me feel better about mine.
Thanks
Old 07-21-2009, 01:31 AM
Arc00TA's Avatar
Wasn't it more of a pain to find a 1/2 to 3/8 adapter to use to put that plug in than it was to use a ratchet? Sucks man, easy way sometimes backfires. Hopefully that alumaweld stuff will fix it.
Old 07-21-2009, 03:38 AM
Hotroddin's Avatar
needed no adapter... haha
Old 07-21-2009, 07:37 AM
the_merv's Avatar
Fill it through the Shifter next time..
Old 07-21-2009, 08:31 AM
Gen414's Avatar
No too difficult in popping off tailhousing while tranny is still in car. Personally, I would locate someone that can weld aluminum around you, yank it off, clean it up for them REAL good, that way all they have to do is prep the material. You problay bring something covered in ATF and they probaly tell you to go home.
Reason I say weld it up is, that crack COULD turn ito a bigger crack, and cause a failure of some sort, and you not even know it...like crack opens up, you are on trip somewhere, fluid starts leaking out, and before you realize it, tranny is empty, and you lock the tranny up in teh middle of teh desert with no water, no food, snakes, serial killers, and we never hear from you again
On a serious note, I do vote to have it repaired correctly though. GL
(Oh yeah, try not use an impact for assmebly, except lugnuts )
Old 07-21-2009, 11:44 AM
Hotroddin's Avatar
i did fill it through the shifter BTW. and thanks gen, i think thats the plan now.
Old 07-21-2009, 08:16 PM
NVR_SPDS's Avatar
I agree with Gen, have it welded up. JBWeld, and that type of thing hardly ever works for anything, especially with leaks.
Old 07-22-2009, 04:24 PM
Gordon0652's Avatar
TIG it up!
Old 07-22-2009, 05:19 PM
camaropilot's Avatar
I can weld it for you PM me.
Old 07-22-2009, 08:13 PM
miller456's Avatar
man this is way off topic and a joke but I have seen multiple threads you post in b/c i was doing research on monster clutches, and I have to say you fail miserably at spelling the word "the" lmao.
Old 07-23-2009, 12:43 AM
Hotroddin's Avatar
Lol "teh"
and your in Cali dude, how are you going to weld it?
Old 07-23-2009, 07:37 AM
the_merv's Avatar
When you ship it to him and he receives it.
Old 07-23-2009, 09:03 AM
Gen414's Avatar
On purpose (obviously)
Quick Reply: Im F*CKING stupid!
