Car won't shift into third @ high RPM
I was running my car yesterday, and every time I tried to shift into 3rd @ around 6600-6800 the shifter would be in 3rd, but I got nothing. And I had to use some force to get it out. Anyone else have this problem?
Specs:
Pro 5.0 Shifter
McLeod Street Twin Borg & Beck Clutch
McLeod Adj Master Cylinder
New GM Slave Cylinder
Specs:
Pro 5.0 Shifter
Specs:
Pro 5.0 Shifter
Specs:
Pro 5.0 Shifter
Is this the first time this has happened? Is this a old setup? Or new (I know you say new slave, but what about rest)?
When you say, you "got nothing"...meaning, when you released the clutch pedal, nothing would happen?
Does the tranny shift fine under nomal driving, or even less "aggressiveness"?
Does this happen in ALL gears or just 3rd?
Yeah, when I shift, it's like i'm in neutral. But the shifter is engaged (Not a miss-shift). It takes some force to get it back out, then it will go in.
It shifts fine under normal driving and less aggressive driving. Just when I'm quick shifting @ high rpm.
I only was running it to 3rd. So i'm not sure about 4/5. The 1-2 shift was just fine.
I had the same problem recently. It's 1 of 3 things, master, slave, or clutch. Mine was doing the same thing. Physically in gear according to shifter postion, but NOT in. It ended up either being my slave or clutch...i replaced both so i am not sure which it really was. Almost postive it was clutch, it was not disenguaging properly.
sounds like it might be a cracked shift fork. i had the same problem before, but mine would grind going into third. I would hit third and seemed like i was on neutral, then had to yank it out to shift to some other gear til finally it gave out completely and had only 1-2 and 5-6.
Here are some pics of a tranny I am rebuilding right now, first one is cracked fork pad:
And this one is of a casting mark on the shift fork, and is very easy to understand why the aluminum forks break (even though this is not the 3/4 fork, the 3/4 fork DID have some casting flaws as well, the 1/2 just was worse off, and wanted to show some pics of more damage)
OK so why is it hanging up in 3rd gear like that? bent shift rod, possibly, or fork.
BUT, if you went out last night and it did fine last night, it SOUNDS like a hydraulic or clutch issue, which is more in lines with a "inconsistent" problem.....one that happens every now and then, as opposed to all teh time.
Normally with something mechanical, like a bent shift rod for example, it will happen all teh time.
