Any reason an MN12 would shift better than a Camaro T56
Old 11-25-2009, 08:18 PM
sciff5's Avatar
Default Any reason an MN12 would shift better than a Camaro T56
For some reason every lsx based car I've driven with an MN12 like the c6 vettes and gtos the ease of shifting is a hell of a lot better compared to any standard t56 I've ever driven in any camaro / fbody
I have a tranny out of a ws6 in my ls1 rx7 and to me it feels almost like tractor equipment so I'm getting it rebuilt more than likely with the stage 2 equipment from tick performance. Wanted to know if anyone has done this and if it effected the way the car shifts for the better or worse. I just want to be able to go from gear to gear with ease at WOT, at the redline and get to the next shift quickly and without worrying if I'm hitting the right gear.
Old 11-26-2009, 07:30 AM
85MikeTPI's Avatar
The MN12 and late model MM6 units all have double/triple cone synchros, over the single/double ones on the Fbody units. They basically have 33-50% more friction surface on the synchros to make shifting smoother..
I've built about a dozen Fbody units using the newer synchros, by using a C5 T56 as a donor. It's expensive, but gives you the smooth shifting, while retaining the MM6 gearing that the Fbody's originally came with.
Usually when you put in the billet keys/etc., the shifting gets a bit more difficult/notchy, but that's not the reason most people rebuild.. They want the strength&reliability the billet/bronze upgrades offer.
Old 11-26-2009, 10:32 AM
LS123's Avatar
Mike is the expert when it comes to upgrading the F body T56 to Vette internals!!!!
Old 11-26-2009, 10:59 AM
sciff5's Avatar
Jeesh knowing that. instead of building up my t56 for 1k I might as well sell my T56 and I could prob get an MN12 for short money (plus I believe they are stronger units as well right?)
Old 11-26-2009, 11:11 AM
85MikeTPI's Avatar
It's an option.. Depending on how you feel about the wider gear ratios. They work better in heavier cars, and it's up in the air if they are stronger or not. They are warranty-rated at 450lb-ft, the same as the Fbody units.
FWIW, I have a GTO unit ready/waiting for assembly, if you're interested:
https://ls1tech.com/forums/lsx-parts...l#post12518227
Old 11-26-2009, 11:55 AM
sciff5's Avatar
Just checking out the ratios, having a shorter first gear would be less than desirable in my car especially as I add more power. These cars already have a tough time finding traction. The shorter 5th gear is better though, cause right now when I shift into 5th the car falls on its face.
I was thinking I could probably straight swap my tranny for an MN12 I am just trying to make sure it would actually give me the feel I'm looking for, the ratios will work, and how different the shifter location is. I know I'll have to modify the shift handle to come up in the stock location in the rx7 but that shouldent be a big deal
Old 11-26-2009, 08:27 PM
85MikeTPI's Avatar
Yes, your lightweight car wouldn't like the wide ratio trans much. The shifter would be exactly the same as your LS1-T56 after swapping over the shifter base and offset lever.
If you find a good deal on a non-Z06 C5 T56, that would be the ideal swap into your LS1 housing. Where are you located?
Old 11-26-2009, 08:29 PM
sciff5's Avatar
whats different about the non z06 c5 tranny?
I'm in mass
Old 11-26-2009, 08:46 PM
85MikeTPI's Avatar
I'm in mass
The non-Z06 C5 T56s use the same MM6 narrow gear spread as the Fbody T56s, but with the upgraded double/triple cone synchros. You can throw all the internals from one on a GTO mainshaft and have your existing trans shifting like the MN12, but with the same gear ratios you have now..
I just day-tripped to Mass to tour the factory-five production. But the 12hr round-trip drive wears you down..
Old 11-27-2009, 12:08 PM
PewterScreaminMach's Avatar
The traction difference was huge in my car going from the stock gearing to the MN12 on Nittos. With the ET Street Radials traction is fine with around 400rwhp on the street, but I could see it being an issue on, say, a 100 shot in first gear without a burnout. Nittos were pretty much useless (I have 4.10s, as well).
Old 11-27-2009, 12:14 PM
sciff5's Avatar
So it got harder to hookup with the Mn12 vs stock gearing?
Quick Reply: Any reason an MN12 would shift better than a Camaro T56
