flywheel bolts
Old 12-05-2009, 01:59 PM
txcarbuilder's Avatar
Default flywheel bolts
Does anyone know which LSx engine installation has the longest bolts for the flywheel to the crankshaft? I have a crank out of a 6.0 from a Hummer that had a spacer on the rear that had to have used longer bolts than some of the others. I am doing a custom installation with a different transmission and need some longer bolts than the ones I have from a 5.3 that just has the flexplate on it. Thanks
Eric
www.kitcarchassis.com
Old 12-14-2009, 09:58 PM
Anybody know anything about this??
Old 12-14-2009, 10:51 PM
3406a's Avatar
Im wondering this same question on the PT forum. Getting rid of my 4.8l and going to 5.3l.
Old 12-15-2009, 04:33 PM
jmd
jmd's Avatar
LS1Tech 20 Year Member
Some of the truck cranks (your 6.0) were shorter and used a spacer w/ the flywheel. Other cranks (your 5.3) were longer and didn't need the spacer.
Try shopping for a late 90s 6.0 truck. If they're longer than your 5.3 bolts, there you go.
Old 12-15-2009, 05:22 PM
SNLPerformance's Avatar
The Cadillac CTSV uses an abnormally long flywheel bolt for the dual mass setup they use, not sure if it will work with your setup but it is the longest bolt out there.
Old 12-16-2009, 01:24 PM
3406a's Avatar
Im not sure about txcar but the bolts that I ordered with the spacer are 28mm long and the CTS-V bolts are 29mm. I need something in the 35-40mm range with my spacer and the flywheel. I was debating about getting a new flywheel if I can find the correct one for my app, or finding the correct M11x1.5 bolts which seem impossible. Ideas anyone? How about short full thread headbolts that I can cutdown?
Old 12-16-2009, 10:20 PM
Thanks, I will check on the CTS-V bolts. I needed longer bolts for another conversion I did with a custom flywheel. Those 11m/m bolts are impossible to find and so I ended up having them made by ARP. They were 3 inches long and cost $12 apiece.
Old 12-18-2009, 05:00 PM
SoJersey05V's Avatar
got a part nmber on the CTS-v bolts??? doing an oem install on my V and want to order new bolts.. thanks
Old 12-21-2009, 01:34 PM
3406a's Avatar
The number the stealership gave me when I called was 12563485. Said they were 29mm long.
Old 01-21-2010, 08:48 PM
^^ thanks man!
Old 01-21-2010, 10:56 PM
6.0 silverado's Avatar
You can also search around mcmaster carr's website.
http://www.mcmaster.com/#cap-screws/=5ha63x
The bolts are a M10-1.5X??
They sell them anywhere from 16mm-40mm and they are a lot cheaper than the dealer. They are class 10.9 bolts so strength won't be an issue.
The bolts for my ls1 are M10-1.5X40
Old 02-05-2010, 06:01 PM
dustiebutt's Avatar
I called Mcmaster Carr and they don't even have any M11 bolts..........anybody else figure out another option for M11 Flywheel bolts longer than 29 mm ?
Old 02-12-2010, 09:22 PM
slowrollin93's Avatar
M11x1.5 and cheap
http://www.summitracing.com/parts/NAL-12563533/
Old 02-13-2010, 05:20 PM
dustiebutt's Avatar
Originally Posted by slowrollin93
Those are 23 mm long
Old 02-13-2010, 05:21 PM
dustiebutt's Avatar
$10.39 Each
Old 05-10-2017, 06:34 PM
xEtherealx's Avatar
Digging this up, but $3.50 each and $5 shipping
https://www.briantooleyracing.com/br...-19257940.html
Quick Reply: flywheel bolts
