Removing clutch pedal spring when installing TICK MC?
I reading through the instructions provided with the TICK MC, and they recommended removing the spring that is on the clutch pedal assembly for a better feel and quicker engagement of the clutch. Wondering how many of you guys have done this and what your thoughts are?
Joey may jump in here and update us, he said that they were really backed up lately and he hadn't had quite enough time to get on tech.
Bumping this to see if there is anymore info about removing the clutch pedal return spring? I just installed a Monster Stg2 with a Tick MC and I have no engagement issues, but my pedal is low and has a dead spot at the top of its travel. My spring is still installed, but I am thinking that I should be removing it now. Will removing it result in worse pedal return?
the spring pullls the pedal up from the engaugement point causing a dead spot in the pedal. I removed mine and no dead spot. the pedal "sits" on the engaugement point. hope the explanation helps.
