drill mod while MC is already installed.
Old 01-15-2010, 03:01 AM
franksaltz28's Avatar
Default drill mod while MC is already installed.
Is there any way to do the drill mod now that the master cylinder is already installed, or is it to late. Would i have to take the whole master cylinder out.
Old 01-15-2010, 09:11 AM
Bobatsuperior's Avatar
You need to take it out, evern if you could push that little pin out you would loose it or just plain old wouldnt be able to get it in. I did it once on a car with the motor removed and it was still a pain
Old 01-15-2010, 10:58 AM
the_merv's Avatar
I'd remove it.. that reduces the risk of breaking it.
Old 01-15-2010, 11:20 AM
How hard is it to remove the MC? Is there anything else i have to take off before i can get to it.
Old 01-15-2010, 11:27 AM
Banned Village Idiot LS1BLKSS
BLK:UFO's Avatar
i would remove it, and be very very carful when you drill
Old 01-15-2010, 04:41 PM
6.0 silverado's Avatar
It's simple. Pull the rod off the clutch pedal, disconnect the line at the tranny and pull the two nuts on the firewall. Should slide right out.
Old 01-15-2010, 04:44 PM
Edit: don't forget the reservoir and don't get any fluid on the paint!
Old 01-15-2010, 07:39 PM
98LS16T56's Avatar
I will be doing this tommorow. will post results
Quick Reply: drill mod while MC is already installed.
