t56 magnum(tr-6060) has anyone got these to fit an ls1 f-body yet
Old 03-21-2010, 09:02 PM
nmass399's Avatar
Default t56 magnum(tr-6060) has anyone got these to fit an ls1 f-body yet
Wanted to know if anybody has put one in there ls1 f-body and got it to work good, is there any changes needed to be made like different clutch or slave or bellhousing? Also can these be faceplated like a t-56? Would there be a need for a different length driveshaft that the stock t-56 has?
Old 03-22-2010, 02:55 PM
nmass399's Avatar
Nobody have any info on these transmissions at all, i already did a search before posting and saw where some were having trouble getting it to fit with the shifter.
Old 03-22-2010, 04:30 PM
thesource's Avatar
Why not just have your unit face plated and have a Viper mainshaft installed? The T56 Magnum is not exactly a direct fit into your application.
Old 03-22-2010, 06:47 PM
ssgunny's Avatar
There is a place out of Indiana that has a retro fit kit for the TR6060 in to a C5 and is currently working on one for the Fbody. I am not sure how far along they are though.
Old 03-22-2010, 06:58 PM
85MikeTPI's Avatar
The Magnum and the factory TR6060 are different externally. Which are you specifically asking about?
There's an old/long/on-going thread on the Magnum here:
https://ls1tech.com/forums/manual-tr...56-magnum.html
Interesting swap article, seems to imply not much needs to be changed from the Magnum except shifter and driveshaft...
http://www.camaroperformers.com/cama...ion/index.html
Old 03-23-2010, 01:24 AM
nmass399's Avatar
I have been thinking about it, the main reason for the switch would be because of the bigger and stronger gears themselves, i have seen some pics of what high powered combos have done to the gears in the t-56 and just want to spend the money on the something better
Sounds good i will have to do a search on them unless you have a website or something.
Thanks man, i read about the got my new trans on here but it did not say if it was finished or was working.
The 68 camaro article is a good one i did not know that the bellhousing had to be modified that's the exact one i have in my car right now. Also was not sure if the slave was the same and the clutch would work.
I was not sure how much of a difference externally the tr6060 was from the t56 magnum so i just put both up there but now i know its gonna have to be the magnum.
Old 03-23-2010, 04:57 AM
LilJayV10's Avatar
Do a search on Black Bird, I am pretty sure he put one in.
Old 03-24-2010, 01:10 PM
nmass399's Avatar
thanks man anyone else got some more info
Old 03-28-2011, 02:36 AM
alecat454's Avatar
Yes I just got done with my install of the t56 magnum in my 1999 camaro and it was very painless
Old 03-28-2011, 09:59 AM
Jeremy@RPMTransmissions's Avatar
We have a direct fit Magnum with a modified F-body/GTO tail housing. It retains the torque arm mount and original shifter and shifter location.
Old 03-28-2011, 10:06 AM
LS1TECH Sponsor
Jonathan@Tick's Avatar
We offer a direct swap t56 magnum as well. Heres a thread we created a few months ago on the subject: https://ls1tech.com/forums/manual-tr...-body-gto.html
Your bellhousing, clutch, slave, driveshaft, shifter, crossmember, trans mount, and torque arm would all work with our converted unit. It also comes with new sensors and switches to plug up to your f-body or GTO. As sold from tremec, the t56 magnum doesn't have the correct backup light switch or speed sensor for your gm f-body or GTO. It also does not have the correct tooth count on the speedo reluctor from tremec but we change that to a custom 17 tooth reluctor so that no programming is necessary. It is truely a bolt in replacement.
Old 03-28-2011, 10:48 AM
Mereniuk's Avatar
I Just installed a Level 6 Magnum from RPM, install went smoothly!
Just waiting for the 4 feet of snow to melt now
Old 06-10-2011, 02:55 PM
ws6_34's Avatar
i have a 2001 trans am and i need a new transmission. i was looking at the level 4 t56 transmission you have for sale and was wondering if it needed anything for it to bolt up to my car thanks
Old 06-10-2011, 03:18 PM
Nope, the Level 4 T56 will bolt directly into your car with no modifications.
Old 06-10-2011, 03:38 PM
ws6_34's Avatar
does that transmission come with a shifter? if not then i can just use the one i have. and i also wouldnt mind having the bronze shifter bushing and the bronze fork pads.
Old 06-10-2011, 03:47 PM
They don't come with shifters, you can just reuse your original shifter. We sell MGW shifters with out transmissions. They are VERY nice, one of the top of the line shifters available today. You can add one to your transmission for $209.00. You can also add the shifter bushing and fork pads to your Level 4 trans for $150.00 and I will throw in the shifter bushing for free. Let me know if you have any more questions.
Thanks again!
Old 06-12-2011, 01:06 PM
ws6_34's Avatar
Thanks again!
thanks for the offer i appreciate it. and i just have 1 more question. is there any way i can order online?
Old 06-12-2011, 03:21 PM
No probllem at all.
Yeah you can order online just shoot me an email at jeremy@rpmtransmissions.com and I will get all the info that I need to process your order that way. Thanks much and I look forward to hearing from you.
Old 06-13-2011, 11:20 PM
ws6_34's Avatar
just ordered my level 4 tranny from rpm transmission ill let yall know how everything goes
Old 05-11-2016, 12:55 PM
TexomaMan_X2's Avatar
Default well
Well how did these work in the cars? worth it or not?
Quick Reply: t56 magnum(tr-6060) has anyone got these to fit an ls1 f-body yet
