Shifting question for any manual transmission
Old 06-16-2010, 07:04 AM
LS14EVR's Avatar
Default Shifting question for any manual transmission
Just curious if what I've been doing is a good or bad habit that I got into. Lately in any manual transmission vehicle if I'm in 5th (6th) gear and coming to a stop sign or stop light, when I slow to the point where the tach is around 1K rpm +- depending on vehicle, I just pull it out of gear. No clutch. I only do it when it will come out of gear easily. My reasoning for this is it would seem to me this is less wear and tear on throw out bearing etc. Is it bad for something else though? This way I'm not holding clutch in while sitting at stop light, or having to push clutch in, and let back out in neutral, then push in again before taking off. Or is sitting at a light with clutch pushed in not that hard on a throwout bearing? I've been told it's not a good thing to do.
Old 06-16-2010, 07:39 AM
th3unwant3d1's Avatar
That bogs engine down, engine wrkn harder to because of such a high gear, why throw in nuetral and ease on the brake? Brakes are easy to replace....
Old 06-16-2010, 10:19 AM
SPEEDYws6's Avatar
You aren't going to hurt anything. You can feel when there is no load on the gear and if it pops out with little force it isn't going to tear anything up. But doing it to save the throw out bearing is kinda dumb. Just go on and say your too lazy to hit the clutch that one time. I know cause I do it too on both my vehicles.
Old 06-16-2010, 10:49 AM
LS14EVR's Avatar
I don't pull it out of gear till almost stopped anyway. Very little engine braking left, and not much brake pedal needed.
You are correct! It is partially be lazy but partially being **** retentive.
That's exactly when I do it, no positive or negative loading so to speak. Just slips out of gear.
Thanks just wanting to make sure I wasn't hurting anything in any manual transmissions.
LS14EVR's Avatar
Speedyws6
2007 Dodge Ram 2500 Q/C m6 13.7 @ 106
Really? Nice!
Old 06-16-2010, 11:34 AM
SPEEDYws6's Avatar
Yeah it makes 660 rwhp on a little shot of nitrous. But it's 2wd so it is a slouch out of the hole.
In that truck if I want to coast I'll give it enough throttle to maintain my speed and it will pop out of gear with ease.
Old 06-16-2010, 11:44 AM
LS14EVR's Avatar
Nice!
Old 06-16-2010, 11:47 AM
SPEEDYws6's Avatar
Thanks
Quick Reply: Shifting question for any manual transmission
