LT1 Clutch Replacement???
Old 08-29-2010, 04:03 PM
LeonbergerG's Avatar
Default LT1 Clutch Replacement???
I have the motor out of my 95 Trans am. Was Taking a look at teh Clutch And it looks Kinda Whipped. What do you guyd think??
What Brand is it anyway? anyone know??
Can I Get just the Fiber??
Old 08-29-2010, 05:00 PM
bigj2717's Avatar
The rivets look like they are showing on the disk, if so its time for a new one. Im not sure of any other companies that have red pressure plates other then McLeod but there could be other brands that do. You can buy just the disk but depending on how the pressure plates looks you might just be better off replacing it all
Old 08-29-2010, 05:03 PM
I think that the pressure plate is ok where can I get a disc?? Will just a stock one work withthis pressusre plate
Old 08-29-2010, 05:06 PM
bigj2717's Avatar
Well it depends on whats done to the car to see if its even worth putting a stock disk back in. Most of the clutch companys sell seperate disk like McLeod
Old 08-29-2010, 05:14 PM
Not much headers exhaust kn intake 58mm tb cam I will look for a new disc. This one measurea about .280 but the rivets are almost even with the clutch surface
Old 08-29-2010, 06:30 PM
The part number is c970043. But I have searched it and it might be a ram clutch or a stock lt4 replacement from advance. I dunno
Old 08-30-2010, 10:26 AM
Billy M's Avatar
McLeod Replacement disc is a 261571
Old 08-30-2010, 10:36 AM
jmd
jmd's Avatar
I can't tell how close the rivets are to the surface of the friction material.
If you get a disc only, you must have the flywheel and pressure plate surfaced / machined. (not just scuffed.) Not all places want to machine the Valeo pull style PP.
A 6 puck is not a stock LT4 replacement disc; the stock ones are a full circle disc.
Old 08-30-2010, 11:23 AM
Thanks will prob ably order one soon
Old 08-30-2010, 12:05 PM
jmd
jmd's Avatar
Post
https://ls1tech.com/forums/manual-tr...ade-valeo.html
Is it a non-Valeo PP? Based on this thread, it sounds like Ram and others use a non-Valeo PP sometimes and based on your disc, it's not a stocker so I'd say you could very well have a Ram you've taken out. :shrug:
Old 08-30-2010, 03:39 PM
Spartan7's Avatar
RAM doesn't paint their PP. And yes, I've heard of some RAM clutches coming with the Chinese PP. I got lucky and got a Valeo one with mine (bought in 2008).
Old 08-30-2010, 04:26 PM
Well I will Just order the new fiber
Old 08-30-2010, 04:41 PM
In-Zane Moderator
ZONES89RS's Avatar
Throw a dics in and let it go back together.
Old 08-31-2010, 10:25 PM
10-4!!
Old 09-01-2010, 08:58 PM
Ne one Know what the Price is on that Fiber from Mcleod??
Old 09-02-2010, 09:52 AM
Billy M's Avatar
Sent you a PM regarding this.
Old 09-03-2010, 11:29 AM
Ordered the mcleod clutch disc for 185 from a local speed shop. Not to bad
Quick Reply: LT1 Clutch Replacement???
