Clutch Recommendation For 600rwhp....
Looking for a real streetable clutch that will hold 600rwhp. Right now Im right around 550rwhp but may be looking to add a bit more power. What do you guys recommend without breaking the bank? I was looking at the spec stage 3+ it was recommended to me buy the guy at rpmspeed. Also what slave and master cylinder would you guys recommend?
Thanks!!!
Thanks!!!
I'd go Textralia but get it from TDP, I heard that Jason from TDP found out where Textralia was getting their parts (Textralia doesn't manufacture anything) and went straight to the manufacturer to get them. Positive comments only about their clutches at lower prices.
i had a spec 3 in my 2000 ss & did not care for it.....
i am on a cartek clutch in my 01 ss & have the 2step set at 7200rpm...... on slicks pulling 1.51 60' ........its a great clutch!
I had a Spec Stage 3 and then a Spec Stage 3+, neither of them lasted all that long in a daily driver that was run hard but never raced. I have a McLeod twin now with a Tick master and GM slave. Have about 6 months on this set-up with no issues. Not saying my solution is your solution. This is more to share my Spec experience. They worked fine, just didn't last very long for me. The 3+ is worth the extra over the 3 if you go that route.
I have a deal for you. I can sell you a Diamond Clutch Stage 2 (12" dual friction setup) for $409. Good for 600hp & has a warranty for 12mo/12k miles. I also happen to have a billet flywheel that has been resurfaced for $150, so that makes the price $559. I'll just charge you $16 shipping, so it comes out to $575 shipped to your door. How does that sound?
Check the websites in my sig. Thanks!
