Which slave cylinder?
What slave should i buy? I found out the one that came with my tranny, is leaking, so i need one asap.
I have a spec stage 2 clutch/fw going in. I know nothing about slaves, other than what they do, so i don't know which is better.
What to order or go pick up tonight by the way!!! And im in the process of dropping the tranny.
Hopefully my frame design gave me enough room to slide it back enough to get it off.
I would go with a GM one. I used a parts store replacement because it was around half the price but now I'm beginning to think it's the cause of a few issues I've been having so I'll probably pull it out and throw in a factory one.
Thanks, i was considering a parts store one. Most that i've read in the past 5 min is pointing me towards gm.
Is the gm one available online for less than what the dealer chargers? What company makes the gm one?
LS1TECH Sponsor
Stick with the GM, found here: http://www.tick-performance.com/tick...raulics/#slave
We've had some leak issues with the cheaper AC Delco unit.
