I'm stranded help por favor
Old 07-27-2011, 07:21 PM
jaysan's Avatar
Default I'm stranded help por favor
Ok so I got out of class and as I press the clutch in I heard a kink . Kinda sounded like a spring kink but I am not sure . So I looked at my pedal and didn't notice or see anything out of the norm. I started my car and it would not go into first. When I attempted to go to first it would sound like its going to die. The car goes into first no problem when it is off . When I try to start it in first it will not turn over . I checked my clutch fluid and it's good . I have to use all my calf muscle to push in the clutch . When the car is on and idling it will not go into any gear . Car is COMPLETELY stock. What can it be ? Thx in advance guys
Old 07-27-2011, 07:29 PM
crainholio's Avatar
Clutch failed, either the slave cylinder or the pressure plate. Not something you'll want to fix in the parking lot, have it towed to wherever you plan on fixing it or having it fixed.
Old 07-27-2011, 07:44 PM
jaysan's Avatar
that stinks . I am thinking it is the slave cylinder because I have to push hard on the clutch pedal. Any upgrades to do while I have the trans out ?
Old 07-29-2011, 09:22 AM
jaysan's Avatar
Should I rebuild the trans while it's out too?
Old 07-29-2011, 11:11 AM
jmd
jmd's Avatar
Post
How many miles since last re-built?
Any shifting issues of note?
Do you want to save money now or time later?
Old 07-29-2011, 12:25 PM
jaysan's Avatar
It has not been rebuilt . There are only 90,000 miles on the car .
No it shifted fine .
I would like to do both if possible
Old 07-29-2011, 12:36 PM
Chaos07's Avatar
i say just upgrade what you can and whats in ur budget
Old 07-30-2011, 07:44 AM
jarretthise's Avatar
do a new clutch and have your flywheel resurfaced. if your car is an lt1, then ws6store sells a preassambled master/slave setup for like 160 or something. if its lsx then buy a new slave and hook her up.. your trans should be fine.. its pressure plate resistance or slave failure
Old 07-30-2011, 10:48 AM
jaysan's Avatar
Yezir it is an ls1 .
Old 08-04-2011, 08:28 PM
jaysan's Avatar
well my fly wheel was fucked and so was my clutch . I noticed that the springs on the clutch were all the way to one side and compressed .
I will post pix .
Old 08-05-2011, 07:57 AM
jaysan's Avatar
Old 08-05-2011, 07:58 AM
jaysan's Avatar
Old 08-09-2011, 11:49 AM
bluenightmare's Avatar
wow, that sucks, that looks a lot worse then when my car got stuck in 6th, I would just recommend getting a new clutch set, while the trans is out might as well replace the slave
Old 08-09-2011, 11:56 AM
Johnnystock's Avatar
Nice clutch!!
Replace everything! Do the drill mod if staying with GM stock master or change to a Tick master if you have the dough. I would not upgrade the trans if its fine, unless you got spare money.
Old 08-09-2011, 11:57 AM
Z284U2TRY's Avatar
lots of slip on that clutch. The clutch plate looks to have lots of material left. How old is this clutch? Did your slave fail?
Old 08-09-2011, 07:05 PM
ls1tafirehawk's Avatar
Man I though mine was bad, but yea I would look into a monster clutch r ram kit. Its probably best to replace the slave and upgrade to a tick adj mc
Old 08-10-2011, 09:02 AM
SPEC-01's Avatar
The disc really doesn't look that bad but the Self-adjusting springs on the plate are fully extended. Additionally the flywheel shows evidence of contaminant seen in the splatter pattern that radiates from the center of the unit. You may have a leaky RMS and this should be checked and addressed while the clutch is out. We offer 7 different single-disc clutches and both steel and aluminum flywheels. We also offer a new Slave and Master (stock and adjustable). Let me know if you need anything and I will be happy to help. See the link below for details (scroll down to the second box). Thanks
http://www.specclutch.com/cars/Chevy/Camaro/2000/Single
Old 08-11-2011, 02:00 PM
SNLPerformance's Avatar
Our Level 1 Monster Clutch is a nice upgrade from stock and will easily hold 450rwhp should you decide to do some mods down the road. Combine it with a lightweight billet flywheel to free up some power and opt for a premium package that includes a new slave cylinder along with release bearing, pilot bearing and alignment tool. Feel free to call me with any questions, thanks. Chris, 817-750-2000
