Hurst shifter
Old 10-24-2011, 12:14 AM
stevenz00maro's Avatar
Default Hurst shifter
Anyone have any suggestions on how to stop a shift from rattling? I have it as tight as it will go and it rattles constantly if I'm not holding it....
Old 10-24-2011, 02:56 AM
c5z16z's Avatar
had the same problem with mine i hated tht so i went with a MGW shifter make the swap well worth it no noise at all its has a rubber boot from the base to shifter the hurst does not....
Old 10-24-2011, 02:58 AM
BirdsSince16's Avatar
Are you sure it isn't the **** that's rattling? I had that happen and just replaced the ****.
Old 10-24-2011, 06:47 AM
NW-99SS's Avatar
Rattling or gear whine? It's easy to stop the gear whine transferring through the stick...I used rubber washers and now I have no gear noise.
Old 10-24-2011, 07:51 AM
Save the manuals!
wssix99's Avatar
What did you tighten? The stick to the shifter? Is this a stock Hurst with the stock stick?
Old 10-24-2011, 10:22 PM
I'm positive it's the shift ****. I don't think my car came with the hurst option, I bought the ****. It's tightened the **** as far as it will go, I don't think it'll go another turn. I was wondering about maybe putting something on the threads? Idk its really annoying....
Old 10-24-2011, 11:44 PM
Save the manuals!
wssix99's Avatar
Is your **** attached with a set screw, or did it screw on the end of the post like a nut? (If its the latter, it shouldn't rattle unless something is broken inside - in that case you should take it completely off, shake it, and see if it will rattle off the stick.)
Old 10-25-2011, 02:14 PM
I've taken the shifter off the stick and drove it and it doesn't rattle at all, so it has to be the ****. Anyone know of something I can do? washers? Put something on the threads?
Old 10-25-2011, 03:06 PM
7camaro7's Avatar
what **** do you have?
Old 10-25-2011, 04:31 PM
The factory oem hurst, I bought off someone one here....
Old 10-25-2011, 07:44 PM
It might be where the threaded bolt inside the **** is glued in or w/e. You might try threadlocker if you don't see yourself having to pull the **** any time soon. I pull mine every time I wash the car to clean my shift boot. I'd just get a new ****, but that's me.
Mine had a backing bolt that fit on the threads below the ****, and I kept it tight against the ****, but the **** rattled around the threaded bolt.
Old 10-26-2011, 07:40 AM
Save the manuals!
wssix99's Avatar
This is the shifter with the "H" embossed in the top, right?
Did you also shake it off the stick to see if there is something loose inside?
I'd next take the stick of the shifter and then check the play in the **** vs. the stick. It should be solid. If it moves then that would indicate the thread is loose from the ****.
Old 10-29-2011, 09:40 AM
Yea its the **** with the H on the top and I've checked the play and it seems to be tight to me. I think I'm gonna try putting something on the threads....
Old 10-29-2011, 10:08 AM
My shifter was rattling and I couldn't actually recreate the sound by moving the handle. It really only happened with the fine vibration that occurred during driving. Just my experience.
Old 10-29-2011, 03:17 PM
Yeah that's really what mines doing, it only kinda does is when I'm the rpm are low....
Old 10-29-2011, 04:35 PM
karpetcm's Avatar
Ive had that happend to me on a few occasions, once was a few nickles and dimes stuck right by the shifter and the other was the **** itself. Pull the **** off and turn the car on and see if it rattles still. Atleast you can rule that out if it still does.
Old 10-30-2011, 12:40 AM
Save the manuals!
wssix99's Avatar
I wrapped Teflon pipe tape around the threads of my stick, but not for vibration. It helps me tighten things up just a tiny bit so that when I crank it down all the way, the **** is pointed straight. (Without the tape on my stick, the **** would point at 3:00.)
So, if you are sure its looseness on the threads - I'd suggest the Teflon tape and have had great results with it.
Quick Reply: Hurst shifter
