Monster clutch and tick master review
Old 04-27-2012, 08:01 PM
GoFastKid's Avatar
Default Monster clutch and tick master review
Just wanted to share this information with those of you that may be in the market for a new clutch and or master. I took advantage of the $100.00 off Tick Performance sale had on Monster clutches last month. I read several reviews (mostly all great) and spoke to Chris direct for a decent amount of time about what clutch and new master would best suite my application. In the end I went with a stage 2 and a new tick master and slave unit. I was told over and over by Chris himself that the stage 2 with their master cylinder would drive almost like stock. 5% stiffer to quote his exact words. Well last week I installed everything and the outcome wasn't remotely close to what Chris said it would be. The pedal is so stiff that after a short while driving the car my leg feels like it had been hit with a bat. I called monster and spoke directly to them about it and they said it wasn't their clutch making it so stiff, it was the Tick master. He said add another 12-15% over the factory GM master along with roughly another 5% with the stage 2 clutch. I mentioned to him that Chris failed to mention this to me and he went on to explain that Chris should have passed that info along and his only thoughts as to why he didn't is because he is fairly new at Tick Performance. He also mentioned I wasn't the first person to have called with this complaint and that he was going to message Chris personally and explain to him that he needs to pass this info along to the consumer.
Long story short, I would have never bought the Tick master if I had known this information before hand. So I've basically wasted over $150 on a master and I'm currently stuck driving a car with a stiff *** clutch until I can afford to buy and replace the Tick with a new GM master. Just wanted to share this for those who may be in the market.
Old 04-27-2012, 08:43 PM
2000NemeSS's Avatar
I need/want the Tick Master Cylinder for awhile now, I cant stand shifting at even 5500 and needing to put my foot under the clutch pedal to bring it back up, kills me on the street against new 5.0s!
Old 04-27-2012, 09:02 PM
Conrad's Avatar
If you're wanting to sell the Tick MC you can PM me.
Old 04-27-2012, 10:44 PM
blwn-by's Avatar
in all the threads ive read most of the guys have said that pedal feel was much stiffer than stock so im not sure why you didnt see that if you read tons of threads... just my .02
Old 04-29-2012, 08:35 PM
fergymoto's Avatar
You must have weak legs.... it's not nearly as stiff as you make it out to be. At least not in normal cases.
Old 04-29-2012, 11:05 PM
johnny89345's Avatar
well i can vouch for monster i just installed a level 2 monster and have a two month old tick. honestly i hate how soft it is. i bled it for prob about 4 hours because of all the reviews ive read about how heavy it is or should be. this clutch it by far the easiest and smoothest clutch iver ever had. compared to my centerorce i just threw out its about 10% of the effort literally. start hittin the gym budd
Old 04-30-2012, 10:31 AM
*02WS6TURK*'s Avatar
Just installed my new Monster Stage 2 w/ a Tick Master. It's a lot more stiff than what the guys at Tick said, but after driving it for a few days I'm already use to it. This clutch/master is bad ***! I can bang/row through the gears like butter now. No more sticking pedal and shifting into gears at high RPM's is no longer a issue! Thumbs up for Monster!
Old 04-30-2012, 03:45 PM
dutinsss's Avatar
it is stiffer but i think the advantage it has over the stock master definately out weighs it. it's still not as stiff as a lot of even stock cable clutches i've drivin. i've been in mustangs with not even crazy clutches that make our clutches feel like your pressing the gas pedal.
i'd drive it for a while before you decide to swap it out. you may get used to it and change your mind.
Old 05-01-2012, 09:46 AM
bww3588's Avatar
Rub some vagisil on your left leg, grow a pair and use the "man" pedal...Christ...
Old 05-01-2012, 11:45 PM
BlackLS1Bird's Avatar
Hit the gym Sally. I have a Monster Level 3 and Tick and have no issues. Pedal pressure is great. Obviously stiffer than stock but that is expected. If you want a nice light clutch pressure, buy a Honda.
Old 05-02-2012, 07:54 AM
Ballzee's Avatar
OH Snap
Old 05-02-2012, 08:33 AM
gmmusclecarman's Avatar
I ran a level 4 Monster and Tick master with no problems with the pedal sticking or being too stiff. It was just right. Nothing my chicken legs couldn't handle!
Old 05-02-2012, 08:38 AM
167camaro's Avatar
It can't be as bad you make it sound. I have the tick master and it is just a little stiffer than it used to be stock.
Old 05-02-2012, 08:51 AM
sams02Z28's Avatar
Monster stage 3 Tick MC here..its definitely stiffer than stock but personally I like it better..buddy of mine has the same setup and its not as stiff as mine so maybe it has alittle something to do with the install/how your MC is set!!
Old 05-02-2012, 07:55 PM
nochey's Avatar
Just had the tick put on my car today and love it
Old 05-02-2012, 10:00 PM
M6transam's Avatar
I just have a MOnster level 2 and GM slave and GM master..My clutch is just barely stiffer than stock..Not real sure how the Tick Would Make it that bad...Monster has a great clutch..Love mine. I actually wish my pedal was a little stiffer.
Old 05-02-2012, 10:10 PM
HeavyMetl's Avatar
I'm running a Monster Stage 2 and a custom fabbed Tilton 7/8" master. Pedal feel is outstanding, and the clutch is stone cold bad-***...I couldn't be any happier with my setup. I agree with the others, if everything is properly set up it shouldn't be too stiff at all.
Old 05-03-2012, 10:12 AM
GoFastKid's Avatar
Well I'm a small guy. 5'6 158lbs. So I appologize. Those of you who enjoy belittling others, suck a fat one.
Old 05-03-2012, 01:44 PM
Fry_'s Avatar
LOL My Wife DD's the T/A in my sig and she loves the pedal feel.
Old 05-03-2012, 04:24 PM
armyboyatc's Avatar
Be a man. Lol.
I am glad for this info so I can go ahead and start working my right leg out do it doesn't look so gimp next to my left one when I get the tick/monster combo.
Quick Reply: Monster clutch and tick master review
