New monster stage 2. Clutch pedal sticking.
I installed a monster stage 2 clutch about a thousand miles ago. Car has a tick mc. Finished the break in without getting on it hard. now that the break in is done on hard down shifts and all up shifts the clutch pedal sticks to the floor a little and is slow to return.
i have the clutch adjusted just below the level of the brake pedal.
clutch has not been bled since install.
hoping nothing got trashed during the break in miles. let me know what you guys think.
Thanks!
Thanks!
alright. i finally got a chance to work on the car a bit. changed rear output shaft seal and put new fluid in the trans. also re bled the clutch and adjusted the clutch pedal. the pedal is no longer slow to return. it doesn't have very far to go. but it doesn't feel like its grabbing like it should.
any suggestions?
any suggestions?
Correct. like its slipping. no problem with high rpm shifts getting into gear. no problems getting into gear at all.
i forgot to mention the clutch pedal return spring was still installed as well. i removed it along with everything else.
my clutch pedal sits just slightly higher then my brake pedal, and if the pedal is too low you can't fully disengage the clutch, the Tick master has to push enough fluid to the slave for the TOB to push on the pressure plate to release the clutch during shifts. I think your pedal adjustment is way off, I have seen my bud destroy a monster stage III because his clutch pedal was half way down in comparison of the brake pedal and wasn't fully disengaging the clutch. But he didn't like that the clutch released near the top of the pedal so it was further down.
I have a monster stage III w/ a tick master.
When I accelerate hard it feels as though the clutch isn't grabbing until it gets higher up in the rpm. The shift from first to second seems to be the most noticeable. The car already had the tick mc installed when I bought it. Put in the monster stage two and did the break in miles as recommended. I haven't had any wot problems getting into gear. But haven't done much hard driving.
The car had a ram clutch in it before I replaced it with the monster. I noticed when I took the ram clutch out that the pressure plate side of the friction disc was worn all the way down but the flywheel side didnt seem to have much wear. So i don't know if that can be related. But I know I installed the clutch correctly.
Are you sure you're not spinning? Give us a call and we'll go over this in more detail, like I said, it just doesn't make sense how you're describing it.
