clutch upgrade for a ls1
Hey hows it going fellas. Im new to the gm world. So heres the thing, my brother just bought an '02 Z28 and the clutch slave cylinder needs to be replaced. So we're thinking of upgrading the clutch at the same time and he had read that the ls7 clutch kit fits his ls1 engine. I looked up the measurements for both clutches and saw that both clutches are identical in size. I wanted to know if anyone else has done this upgrade and can we keep the stock ls1 flywheel. Thanks in advanced
You will need a new flywheel as mentioned to fit the ls7 clutch , and be prepared to add an adjustable master as the shifting issues with the heavier ls7 clutch setup with self adjusting pressure plate on stock hydraulics are very well documented ...
I bought my 6 speed car with the ls7 clutch setup and I do chase those shift blocking issues on mine , haven't had the free cash in the budget to do the adj master but changing clutch fluid weekly helps a lot. Another thought would be to go ls7 with a light flywheel to get the overall clutch/fly weight close to stock ls1/fly weight and maybe that would cure the shift blocking issues at wot since you will already need to buy a flywheel to run the ls7. Of course this puts you in the monster clutch/fly price range which doesn't have an adjustable pressure plate eliminating that potential problem.
LS7 clutch is a great upgrade for a mild built car. You will need to purchase the entire kit with flywheel. I would also suggest getting an OEM slave for it while its a part.
Installed a bunch of them and never had any issues but I always installed new slaves with speed bleeders along with a fresh built transmission.
If hes going to keep the car stock, go with a Monster Stage 1, if not, go stage 2. They are great clutches, and they have great customer service. Also, you can order it with the slave cylinder from Tick. and get the speed bleeder line too, it really takes the aggravation out of bleeding the throw out bearing style slave cylinder.
Link to Clutch Selection
Sorry it took a little time to get back to this thread. If you ever have questions don't hesitate to PM me on here. The McLeod clutches do work with the stock master and slave cylinders without any modification or trouble. This hands down would be a great upgrade for your setup that would far exceed your expectations from a clutch.
If your going to do a clutch don't waste you time with the ls7 clutch. I would do an aftermarket stage 1 setup with a tick master.If you are planning to do horsepower upgrades I would think ahead and use a stage 2.
I went with a Diamond stage 2 and I am very happy with it.Install a speed bleeder while your at it.
I upgraded to a Centerforce Dual Friction for my stock T-56 and it's been fantastic. Super hard grap at high RPMs and enough give under normal DD. It's in my '99 LS1 swapped Camaro and that car is my DD and I drive about 15K/year in Southern California, so I see a decent amount of traffic. After a while anyone would get tired from the clutch pedal, but thankfully the Centerforce is pretty forgiving and light!
Jeez, ain't this the truth!
