Car rocking during decelleration....
Old 10-02-2005, 09:09 AM
silverTA2002's Avatar
Default Car rocking during decelleration....
Mods in sig.
In pretty much any gear, when I'm decellerating (no brakes), while in gear, at low rpm (1200 or so), the car rocks back and forth a few times and makes a metal on metal contact, "clunk clunk" sound.
Nothing real loud or rough, but it feels like something is loose back there. Any ideas? Could it be the lower control arms?
I hope it's not a rear end issue.
Old 10-02-2005, 09:12 AM
peterock98's Avatar
Check the motor mounts.
Old 10-02-2005, 10:01 AM
P Mack's Avatar
Check the torque arm bolts and mount.
Old 10-02-2005, 02:52 PM
Engine mounts are tight. tq arm bolts and mount is tight.
Could it just be normal slack in the drivetrain?
Also, how much oily stuff should be on the tq arm. I've never cleaned it or anything. It's covered with oil and dirt about halfway up it from the rear end. It's not dripping or leaking or anything. I've just never looked at it. Probably normal after 3 1/2 years of driving.
Old 10-02-2005, 08:23 PM
P Mack's Avatar
Oh, I just saw that in only happens under 1200 rpm. The same thing happens to me sometimes, except it's always when i'm going through parking lots, not so much on decel. Do you have poly motor mounts already?
Old 10-02-2005, 10:17 PM
No poly mounts.
And it really doesn't do it all the time, only every once and a while when I'm coasting at lower rpms.
It just feels like something has slack in it somewhere.
Old 11-16-2005, 06:05 PM
bradl1982's Avatar
Mine does the exact same thing at low speed such as driving through a parking lot. I'd like to know what it is too.
Old 11-16-2005, 07:41 PM
Firebird95's Avatar
Just started to notice the same thing on my new ws6. I hear alot of grinding as well.
Quick Reply: Car rocking during decelleration....
