View Poll Results: High HP clutch choice.
Spec Stage 3+
12
27.27%
Spec Stage 5
20
45.45%
Centerforce Dual Friction
12
27.27%
Voters: 44. You may not vote on this poll
High HP Clutch Poll!
Old 12-20-2005, 05:22 PM
ls1charged's Avatar
Default High HP Clutch Poll!
Im going turbo looking to make over 600rwhp and cant decide between: Centerforce Dal Friction clutch
Spec Stage 5
Spec 3+
From what ive read the stage 5 will hold the power but is noisy,the Spec 3+ SAYS itll hold the power of the stage 5 but with the drivability of the Stage 3 and the Centerfore Dual friction clutch looks good but i havent heard much about it.Please vote and give some reasoning, as im set on picking 1 of these 3.Thanks josh
Old 12-20-2005, 06:12 PM
ls1tech.net's Avatar
(deleted)
Old 12-20-2005, 06:16 PM
ls1charged's Avatar
Originally Posted by ls1tech.net
(deleted)
WTF?
Old 12-20-2005, 06:26 PM
98turbls1's Avatar
That's what I said...I clicked it and luckily no virus but that $hit doesn't need to be on the forum...
Old 12-20-2005, 06:27 PM
V8_DSM_V8again's Avatar
Mcleod..
Old 12-20-2005, 06:28 PM
White_Hawk's Avatar
I had a lot of luck with a Ram clutch that the Stenod guys specced out a few years back. It wasn't a standard LS1 ram, though, it was some T56 stuff from other vehicles. Maybe they can chime in as to what it was. I never made over 500 (made 460 on a mustang dyno), but I never had a problem with it in 30,000 miles of hard driving either.
-Geoff
98turbls1's Avatar
I second that V8_DSM...I like what I hear from their users...
Old 12-20-2005, 06:33 PM
ls1charged's Avatar
thats outta my league i cant see spending $1200 on a clutch.i could buy 2 Specs for that price.Please choose from the 3 posted. This is a street car btw.thanks again guys the more the merrier.
I have a mcleod sintered on a SSG flywheel in the DSM... Its tough running high power thru a 8" diameter disk into an AWD system....
The flywheel being SFI approved is important. Flywheel explosions suck *** and could really hurt you on a RWD car...
If there were a mcleod dual disk for my car as cheap as the LS1 I'd have it.. I drove a Mcloed dual disk F-body.... Kicks major ***....
The camaro will be getting one. The truck is going to be an auto....
Old 12-20-2005, 06:48 PM
Nate_Taufer's Avatar
Yes you could because that's probably how many spec clutches it will take you to realize you should have bought a McLeod street twin in the first place.
But my vote is for the RPS unit. That's what I'm running.
Nate
Old 12-20-2005, 06:49 PM
Then run a Mcleod single sintered....
Old 12-20-2005, 07:05 PM
White.Lightning's Avatar
McLeod vote here. Twin disc going into my car. $1200 isnt bad considering you are getting:
McLeod Street Twin Dual-Disk Clutch, Pressure plate, Steel Flywheel & new master cylinder
Add to that an updated slave and pilot bearing and you have yourself a damn near bullet proof clutch setup. I know there are exceptions to the rule with people having issues with almost every brand of clutch, but this clutch is supposably the "best". There is always going to be people bashing one brand from a bad experience or even preference of engagement feel, etc.
I was in the same boat, wanted to go Spec, looked at Ram, but decided on McLeod due to the good reviews it has gotten. I would also recommend Textralia over a Spec due to the high reviews it has gotten. Both the McLeod and the Textralia offer "near stock" pedal feel versus the huge left leg you will get from a Spec 4, 5, or 3 for that matter.
Ultimately it is up to your preference and budget, but I would recommend the McLeod not being biased since I am putting one in my car but since I was in the same boat as you a month ago. Do the McLeod and drive the bullshit out of your car.
Good luck man
Andy
Old 12-20-2005, 07:09 PM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
i run a ram 910 vds and im very happy with it
Old 12-20-2005, 08:12 PM
Blown SS's Avatar
Give Cartek a call , mine was holding fine at 580 rwhp before I swapped for a auto . It's a killer clutch , and the price is right .
Old 12-20-2005, 08:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
I like the SPEC 5.Peddle pressure is stock or even softer than stock and it drives great in traffic.
Mcleod is a 50/50 .I've pulled out a good share of blown up one's.
RPS- I hated it.Lasted 1k miles in my Vette and they didn't stand by there product at all.
Old 12-20-2005, 08:24 PM
777's Avatar
I'll be running a ram clutch when I go with a high horsepower setup.
Old 12-20-2005, 09:32 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
wow glad i saw this thread....id like to see what the majority vote is as well since im in the same boat....i notice not many have said or mentioned the Centerforce dual friction....any reason?What are the real diff between the 5 and 3+ Specs?
Old 12-21-2005, 12:00 AM
2000 Tran Zam's Avatar
at least in their lower end clutches, they blow up after like 50 miles put on them. my buddies did and he hated it. he said it started slipping right away, he couldnt even go up hills from a stop...
Old 12-21-2005, 12:08 AM
South Bend Clutch Feramic FE series... I have seen their diesel truck clutches built just like this take what for many other clutches would be a *** whooping.
They can also build them on a sprung hub..
Old 12-21-2005, 12:35 AM
ls1charged's Avatar
ok so the centerforce is junk.....so what are the differences between the Spec 5 and 3+?Also anyone have links to where i can get either or the Mcloud cheap?I already have a flywheel and new slave and master.
Quick Reply: High HP Clutch Poll!
