shifting trouble, urgent help needed
Hey, happy holidays, now that the formalities are out of the way, I just drove 500 miles to see my parents up in the northeast, during the trip sometimes the manual transmission wouldn't want to go into a certain gear. Stopped at a rest stop, it refused to go into reverse, so I had to push the car out of the spot, later however, it would go into reverse sometimes. This problem with all the gears is relatively new, however it was always tough to go into reverse after I finished dropping the drivetrain to change out the clutch back in october. Sometimes the shifter doesn't want to move into position, I can force it in there, but not with reverse now, it refuses to go regardless of how much force I put on the stick. I could really use some help regarding this, I don't know where to start looking to investigate this problem. Is it an issue with how I reassembled it? Everything seemed fine when reinstalling, except the throwout bearing was rattling around a little more. Has anyone seen this before? As always, any help appreciated
Well, unfortunately I don't have the time or the capabilities to deal with this right now, I'm heading back down to VA in a week, I don't have a lift at my disposal so I am just going to try and find a tranny shop up here, see if they could fix it. I'd rather figure it out myself but I don't have time. Thanks for the comments
Im in the same boat, having a similar problem except mines limited to reverse only. Im hoping its something simple like a fluid change, TO bearing or clutch. I really dont have the $$ to be dealing with shift forks or syncros right now.
