slipping clutch???
slipping clutch???
Was driving in 6th gear today, and kinda floored it and the rpms started going up but the car wasn't going faster then as I let off gas, and then fed back into it, it seemed to grab again, but now EVERY time I push on gas harder than normal driving it's like the car doesn't go anywhere. Need new clutch? What else could be going on?
master/slave cyl's are brand new. I swapped this from auto to manual last year, and bought a used spec III clutch.
What kind of clutch should I go with? I'm having tranny problems too, grinds when going into 3rd or 4th. It WILL go into gear but grinds BAD. Just working on coming up with money to have fixed.
Should I go with ZO6 clutch? I'm running around 400rwhp heads/cam package and will be spraying 150 shot when I come up with the money. Thanks for the help.
nah i've heard the z06 clutches are just barely better than stock ones. i've only got around 330 hp and have a spec stage 2 and love it. it seems like with spec, its either a hit or miss, you either love or hate it. i say go with a stage 3, especially for when that 150 shot tempt you and you want the insurance of knowing it wont slip.
So which clutch should I go with? I need to know asap so that I can buy it and put it in.
Does spec refurbish their clutches, or am I SOL and have to buy a whole new one?
Does spec refurbish their clutches? I currently have a spec III am I going to have to buy a whole new flywheel, clutch and pressure plate?
Also am I going to have to replace my TO bearing? The one that's in there is only a year old
