Slave quick disconnect..
Old 02-07-2006, 08:27 PM
My90Iroc's Avatar
Default Slave quick disconnect..
As for the teflon ring on the quick disconnect do you put it into the male part to release the slave line or do you pull the teflon apart and out?
I know it's a stupid question but I wrestled with it for a bit and was worried about breaking that teflon ring so I figured I'd ask before doing something dumb.
Old 02-07-2006, 08:37 PM
dschmittie1's Avatar
push it into the slave and pull the line out away from the slave. Use to flat blade screw drivers to do it
Old 02-09-2006, 01:21 PM
My90Iroc's Avatar
I must be doing something wrong, I just spent 4 hours on this motherfucking "quick" disconnect and it's still on there. I push the teflon in as far as I can and then I push the line in but once I try to pull the line out it just pulls the teflon back out and doesn't disconnect. What the hell is going on here?
Old 02-09-2006, 01:46 PM
this is one where having 3 hands in helpful push the disconect in and hold it in then pull out on line while still holding the white ring in. kinda a pain in the *** to do by yourself with out the "special" tool
Old 02-09-2006, 10:00 PM
thunderdan74's Avatar
It makes all the difference to push in on the line and hold it as you push in the plastic ring. That takes the load off the spring tabs that the ring is trying to spread open. I hate using the screwdrivers! They're chewing up the ring. Wish I knew where to get the tool!
Old 02-10-2006, 09:34 AM
My90Iroc's Avatar
Yeah, I'm afraid I chewed up the ring so much that it won't go in enough. I'm not sure if that's true or not but I've not spent about 5 hours on it with no luck.
Old 02-10-2006, 04:50 PM
Anybody konw where to get the the tool, or have the part number for it?
Old 02-10-2006, 04:55 PM
I have one somewhere at my shop it the mess we call our tool room but I just used the screw driver method. I could find the J number and you could probably get a dealership to get it for ya or I am sure snap on or mac make something like it
Old 02-10-2006, 05:56 PM
My90Iroc's Avatar
The J number I got from the dealer was J-36221 but no one had it (napa, carquest, dealers) and when I called the snap-on dealer I only got a machine. I ended up just dropping down my master cylinder.
Old 02-10-2006, 09:03 PM
bilt2rev's Avatar
You can get "J" tools thru Kent-Moore tools. http://www.spxkentmoore.com/
