Car not goin into gear???
Old 03-02-2006, 01:06 PM
35thls1ss19's Avatar
Default Car not goin into gear???
well about 3 months ago i installed a Textralia clutch. I did not do the drill mod. Anyway i broke in teh clutch and even drag the car a few times before it went away for winter. the clutch seemed fine. Last week it was very nice out so i decide to take the car out. It was real hard to get into gear and would barley go into reverse. I dotn no what to do now is it bc it was cold (i never drove the car with 20-30* temp) or do i need to bleed the system some more, or just do the drill mod? i am lost and i am doin H/C swap hopefully this week so i figured i mine as well fix thsi too
Old 03-02-2006, 08:34 PM
The PAT WS6's Avatar
do the drill mod and pressure bleed the system or mity vac, etc. go to ls2.com and look at the jmd method.
Old 03-02-2006, 09:29 PM
jermzz's Avatar
Sounds like the slave cyl to me.
Did you change it when you did the clutch?
Old 03-03-2006, 01:23 AM
yes i did change the slave. the textralia comes with a new one
Old 03-03-2006, 02:07 AM
jermzz's Avatar
Usually when you can't get it into gear its cause your clutch isn't disengaging all the way. If you changed it, I would follow the above advice and bleed it more.
Old 03-03-2006, 04:28 PM
thats what i am goin to try. the only thing that is fishy is that it worked great for a month and a half.... thanks alot for the help
Old 03-08-2006, 07:09 AM
ninobrn99's Avatar
bleed it first, if that doesnt work, then its your slave. just went through the same thing.
Old 03-08-2006, 09:50 AM
calhoon's Avatar
Check the routing of your slave feed line= that it is not too close to exhaust members. Insulate this line if you suspect heat concerns.
Quick Reply: Car not goin into gear???
