hydraulic ????
hydraulic ????
first off trying to learn as much as possable about the whole clucth setup. ok what all do i need to replace if i have a hydraulic problem??? what is in it and what does it do???
Please explain
Brad
Please explain
Brad
Im having hydraulic issues right now, and rather than pull the tranny and trouble shoot, im just replacing everything so I can get it done and over with. Once the old parts are off the car ill play around with them to see what goes in the trash.
did u make sure you line isnt near the exhaust getting heated? i dont remember if it was here or on ls2, but someone just wrapped theirs in heater hose and bleed it. Seems to be working out good for them. Also, did you do the drill mod?
i have done both, i did the drill mod then last night i noticed the mc line was touching the exhaust man so i put heater hose over it then zip tyied it away from the manifold
bleed the system-still same thing doesnt want to shift fast at all..???....
