Tranny Mount Question
hey guys,
after fighting like crazy to get my transmission back in, I started to put the Torque arm mounts back on the transmission.
there are 3 bolts, 2 long ones to hold everything on, and one at the top to hold the two pieces together. well the first few threads on that top bolts are stripped out on the tranny...dunno how
I don't know if there is room to get a tap up there...no way I want to get the tranny back down just to run a tap.
What could I do? Would an after market Torque arm have a different bushing mount that I can use? that doesn't use that top bolt?
I'm also just considering putting a couple of tack welds on the damned thing and calling it a day.
any suggestions?
any suggestions?
Kleeborp the Moderator™
With the torque arm out of the way, and the trans crossmember dropped, you could probably manage to get a tap up there to chase the threads, but I dunno. What you COULD do is get one of the aftermarket trans crossmembers that relocates the torque arm mount off of the tailshaft...UMI and BMR make ones that do exactly that, that still allow a full length torque arm. Vibration might be an issue with those though...
Originally Posted by chpmnsws6
let it sag down and the you can get a tap in it
i'd like to button that up
then i have to try and fight to get the master slave back on the car
stupid thing
