T56 shift points
Originally Posted by transwiz
Ok thanks for the worthless responses.
I know someone who had this problem corrected with custom tuning.
Mike
Mike
Do you have a 6 speed? IF so what are you really trying to say. That your having trouble shifting into 3rd when the engine is above 3000 rpms?
IF this is the case there is nothing you can do in the computer to fix the problem. Maybe you have a synchro out or something or maybe its a clutch problem.
BUT asking how you can change the shift points on a manual transmission is kind of funny ****. You do the shifting: how can you change yourself is what your literally asking.
Mike
Mike
Alright then so the manual has no factory settings for RPM range during shifts.
Thanks for the help.
Mike
Mike
