Bad master seals ?
Bad master seals ?
Hey gang need some advice.
I just swapped to a spec stage 3 from my old Z06 setup a couple weeks ago on my C5. I already had a Mcloed Adjustable master and new slave in it.
I've noticed when sitting at lights or any other time that I hold down the clutch pedal that the clutch seems to slowly bleed. Normally my clutch engagment is way up at the top of the pedal travel. But if I hold it down long enough(20 seconds) when I let off it will grab right off the floor(or wherever I had the pedal). Now as soon as the pedal comes back to the top my engagement is back to normal. And during normal driving with quick shifts it stays up top.
My first thought was that maybe I didnt tighten the bleeder screw enough. But I know I torqued that bitch and upon inspecting my resivior its still filled to the top(no fluid loss).
So my best guess is that the seals in my master are weak and letting fluid by under the extra load of the stiffer spec 3 pressure plate.
what do you guys think ?
My clutch grabs right off the floor and it's been like that since I put the new textraila last year. I hate it. But mines like that all the time.
I think I need a new master cyl.
Is your fluid dirty?
Anyone know if the Rebuild kit is the same for the C5 and F-body ?
