Gear stick problem
Gear stick problem
hi,i have a LS1/T56 in a Gardener Douglas cobra, the engine has been sitting around for along time, gearbox oil was drained when it was shipped over to me(live in the UK)havent stared it yet either , no if i move the gearstick to the left it springs back to its origanol position like normal but if i move it to the right it wont spring back ( in nutrual)
any ideas? regards
any ideas? regards
What kind of stick is on it? If it is bar stock you may have too much mass in the stick and its load at angle is what is causing the problem. Also, what shifter is on the unit? Aftermarket shifters have a long history of internal drag.
thanks
Looks like a factory Hurst shifter. You can calibrate the side to side load by swapping the coil springs is that shifter. Hurst sells a spring set that allows you to do that. Check Mr Gasket's site.
Ah ,well ,I do know my Cobras. What Cobra are you talking about? He did say a Gardener Douglas Cobra. That would be a Kit car Cobra( like an AC derivative) and would place the stick in an Fcar T56 .....in the trunk. Do you know what you think you know?What value is it you think you bring?
GD is a kit car manufacture yes. www.gdcars.com www.gd-owners.co.uk
the chassis is ament for a chevy 350 iron block, but with the use of some conversion plates and 350 engine mounts it fits fine and the gear stick sits in the same place the tko box would have, i will post some pictures later with the body on and where the gear stick comes out.
