Need recommendation for 300-450whp clutch
Old 09-05-2006, 12:03 AM
DoubleTapDrew's Avatar
Default Need recommendation for 300-450whp clutch
I looked through the threads and when i try to search it always times out but what clutch would be a good stock replacement that will still handle up to 450rwhp (I'm going to do heads/cam soon hopefully)?
I'd like to keep it streetable without a lot of chatter or lurching in traffic but still be able to hold the power. The car has 82K miles with the stock clutch so it isn't going to last much longer.
I've been considering: Centerforce dual friction, Spec 3 (don't know much about spec but a lot of people seem to like them), LS7, any others?
Are the RAM clutches any good? My workplace may still be a Ram dealer so I could get one for cost if they are decent.
Thanks for any help
Old 09-05-2006, 12:13 AM
michael402z06's Avatar
i would go with a textralia oz700. byunspeed has them for a good price. they are nice and heard a lot of good things. spec 3's are nice but i see more of them go bad then textralias.
Old 09-05-2006, 12:21 AM
HeapaShifter's Avatar
I think the LS7 clutch would be a good choice.
Old 09-05-2006, 05:24 AM
tim99ws6's Avatar
Ram HD is the only vote in my book if you intend on racing it. After that, i'd go LS6 if you don't intend on racing it much. After that, if you had to, i'd go Textralia, but MAKE SURE YOU WATCH OUT FOR PP BOLTS LOOSENING on the textralia
Old 09-05-2006, 05:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Ram Powergrip HD.
Old 09-05-2006, 08:31 PM
Nate_Taufer's Avatar
I'm not a spec fan. it's definitely a crap shoot with their clutches. The McLeod twin disc has a really good rep, pricey though. Go with the textralia
Old 09-05-2006, 09:57 PM
I checked out those Textralias and they are sweet but they are pretty spendy (I think it was $1100 on their website)! Would the LS7 be a good choice? I looked up the clutch and PP and they'd run me $285 and I think you need to run a LS2/LS7 flywheel which is about $80. I'll do a few runs in the 1/4 but it'll mostly be a fast street car with handling as a goal.
We had a McLeod in the '69 camaro but it was pricey.
Old 09-06-2006, 04:02 PM
99BackNBlackZ28's Avatar
I have an LS7 clutch in my 99, I'd recommend it!
Old 09-06-2006, 05:36 PM
tici's Avatar
I still have the stocker (LS6) and it holds!
OK, I don't drag race... but it holds
Old 09-06-2006, 09:58 PM
00WS6_TA's Avatar
How does the ls7 clutch bolt up? i need a clutch ASAP. Can i use the stock throw out bearing? What all would i need to buy to make this clutch work? I have a 2000 WS6.
Old 09-07-2006, 06:52 AM
Turo's Avatar
Where did you see those prices?
Old 09-07-2006, 01:41 PM
It's cost. I work at a GM dealership
Old 09-07-2006, 03:17 PM
LS1TECH Sponsor
badpewter-z's Avatar
might wanna double check that flywheel then
ive sold a few of theses setups at my dealer and thats half what the cost is for the ls2 flywheel also a heads up the newest p/n for the PP and disc setup is on backorder again thanks GM
Old 09-07-2006, 03:43 PM
BLUE01's Avatar
why the CF 12" ? Will the 11" work too?
Old 09-07-2006, 04:18 PM
Oops you're right. About $170 for the flywheel and $273 for the clutch assuming I'm looking up the right numbers this time. Are these right:
Clutch PN# 24236500
flywheel PN# 12571611
Do I need any other special parts to install that clutch?
Old 09-07-2006, 04:25 PM
LS1TECH Sponsor
YUP but that pp number has been supercedded twice now in the last few months
24238412 is the newest number which no one has in stock nor does gm at this time old numbers are 24236500 and 24237690 theres a few dealers that have stock on those numbers
Old 09-07-2006, 06:19 PM
That really sucks it's out of stock. What the hell is the deal with the different part numbers? That new number you gave me comes up as $193, which is $80 cheaper than the other two, (maybe that's why it's out of stock, it's on sale! )! That part number includes the clutch and pressure plate correct?
Old 09-07-2006, 10:51 PM
LS1TECH Sponsor
yup its alot cheaper and went on back order with in a few days it is the pressure plate and disc. as soon as i get an answer from gmspo tommorow or monday il let ya know when the next shipment will be released
Old 09-08-2006, 12:13 AM
That would be great, thanks!
