Tranny fluid
Old 10-08-2006, 12:17 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default Tranny fluid
I was under my car so I figured it would be a good time to check the trans fluid. I popped the fill cap off and reached in with my pinky, and could feel fluid, but it was just on the tranny case, not a actuall puddle in the bottom of the tranny... So I know I need fluid, whats the best to use? And could this be causing my third gear popping out every once and a while, or is the 100% sure still my syncro?
Old 10-08-2006, 12:41 AM
Revelation Z28's Avatar
shift fork.
Old 10-08-2006, 01:31 AM
whyte95ZRida's Avatar
ATF4 is what gm mechanics told me to run in my t56. They said its for an auto but will work with the t56 and helps out synchros some how. I didn't really listen to the advantages, if any, but my neighbors who are also mechanics said the same basic thing.
Old 10-08-2006, 05:17 AM
Shallow Bay's Avatar
https://ls1tech.com/forums/manual-transmission/290247-t56-fluid.html
Old 10-09-2006, 03:18 AM
jdoyle's Avatar
mobil 1 atf
Old 10-09-2006, 05:30 AM
gonefishn1212's Avatar
i have the royal purple ATF in my T56 its got that limited slip additive alrady in it. been in it for about 10,000 mi now, and no problems
Old 10-09-2006, 09:30 AM
Kleeborp the Moderator™
MeentSS02's Avatar
FYI, the limited slip additive is for the rear, not the trans.
Old 10-09-2006, 09:33 AM
Packy's Avatar
I have always used regular old ATF.
Old 10-10-2006, 07:45 AM
ЯєŧąяĐ Єlˇmˇиąŧřя ™
orangeapeel's Avatar
Originally Posted by @nthony
shift fork.
That thing might be slightly tweaked/broken/bent.
