need to start engine
Old 11-11-2006, 03:49 PM
old and good's Avatar
Default need to start engine
Hi guys im having a bit of trouble. my transfer case is out of the car and i wuld like to start the engine but i cant push the clutch pedal down. is there any way to start the engine by pressing a buton on the clutch or something?
thanks
Old 11-11-2006, 09:55 PM
joshp14's Avatar
Unplug your clutch pedal position switch and jumper from terminal to terminal with a wire or paper clip. This will close the circuit and make your PCM think the pedal is being pressed. The car should start then...just remember not to push on the clutch!
Old 11-11-2006, 10:40 PM
how do i do this?
Old 11-11-2006, 10:41 PM
joshp14's Avatar
Originally Posted by old and good
how do i do this?
read exactly what i put in the above post
Old 11-12-2006, 06:25 AM
yes but where is the clutch pedal position switch?
Old 11-12-2006, 11:39 AM
TTT 4 me
Old 11-12-2006, 12:57 PM
joshp14's Avatar
Get under the dash on by the clutch pedal and look up...the clutch pedal rests against the switch when the pedal is all the way up.
Old 11-12-2006, 01:01 PM
Think i can press it manualy while i start the engine?
Old 11-12-2006, 01:03 PM
joshp14's Avatar
Pressing it tells the PCM that the clutch pedal is NOT pushed, depressing the switch closes the circuit and tells the PCM the switch IS pushed. You will either need to close the circuit manually as I said above, or push the clutch pedal all the way down. Since pushing the clutch pedal all the way down has already been ruled out, again, manually close the circuit as I said above.
Old 11-12-2006, 08:35 PM
98 SNAKE EATER's Avatar
How bout just turning the key on and running a jumper wire to the starter solenoid?
