any way to fit an lt1 t56 on my ls1?
Old 11-15-2006, 08:57 PM
98hardtopZ's Avatar
Default any way to fit an lt1 t56 on my ls1?
exactly as titled, i know the bellhousings are different but could i just get a ls1 bellhousing? i have a local guy with one for an lt1 and i can get a good deal, help me out!
Old 11-15-2006, 09:25 PM
Ping King's Avatar
input shaft lengths are different..lt1 is shorter i believe.
Old 11-15-2006, 10:02 PM
98hardtopZ's Avatar
so no worky on that either? what if i could get that part and the bellhousing...would it work then?
Old 11-15-2006, 10:20 PM
Revelation Z28's Avatar
if you can get the shortened input shaft and bellhousing then itll work.
Old 11-15-2006, 10:27 PM
ls1 joe's Avatar
You will have to change the input shaft, front plate and bellhousing. The input shaft on an lt1 is shorter, the bellhousing is different and the front plate on an lt1 will not bolt up to the ls1 bellhousing.
Thanks,
Amber
T56Rebuilds.com
Old 11-16-2006, 12:57 AM
98hardtopZ's Avatar
how much does the ls1 front plate, bellhousing and input shaft run? used preferrably...
Old 11-16-2006, 08:38 AM
ls1 joe's Avatar
Used bellhousing $150, used front plate $125 and used input $125.
Thanks,
Amber
Old 11-16-2006, 10:38 PM
98hardtopZ's Avatar
so if i could get a perfect condtion lt1 t56 local it would be worth it huh?
Old 11-16-2006, 10:47 PM
ls1 joe's Avatar
If it is fairly priced it would be worth it. Might be just as good to find a LS1 trans as well. Not sure what he is charging you but that part is up to you.
Thanks,
Amber
T56Rebuilds.com
Old 11-16-2006, 10:50 PM
2000LS1TA's Avatar
i think it's a good deal
Quick Reply: any way to fit an lt1 t56 on my ls1?
