Spec Stg 5 :(
Old 01-17-2007, 03:38 PM
koji777's Avatar
Default Spec Stg 5 :(
Just wanted everyone to know my expirience I had with the Spec 5. I installed her, put about 500 miles of daily driving on her.... never over 75 mph, no dumping etc. Went to the track and made 8 passes launching at about 2500-3000 RPM. Got home... clutch was slipping bad. I read a post somewhere where the individual stated a similar case, he then said he removed the spacer and all was well. Hoping for the same results I dropped my tranny and sure enough the clutch was in fine shape .... except for one thing. The clutch disk itself had several hair line fractures.... about 10 in all. I just replaced it with the Tex twin. Watch those 5s' boys.... could cut your legs off!!!!
Old 01-17-2007, 04:55 PM
mike c.'s Avatar
i have had problems with ram clutches like that. i have had great luck with the spec st3 +. it's the only clutch that has lasted for me. did you call spec? do you know what caused it to go so soon?
Old 01-17-2007, 05:39 PM
koji777's Avatar
I've no idea, I can only speculate. Here nor there, I've gone with the Tex Twin.
Old 01-17-2007, 08:50 PM
WestSide's Avatar
Please let me know how the Exo skel does, the clutch is the last thing for me to buy to go full boost! Thanks man, I might bother you by PMs next week or so if you'll have some results?
Old 01-17-2007, 10:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
Sounds like you had the shim in there.90% of the time you can not run the shim with the 5's.If you do,it will slip,wear fast and crack from serious slipping/heat(like most clutches do)
Old 01-18-2007, 08:26 AM
koji777's Avatar
I wish I knew the shim was optional.... I was told to put it in, it came with the kit. I called and was told to install it. Really sucks.... lesson learned.
Old 01-18-2007, 10:20 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
im pretty sure the shim is in mine and no issues at 530rwhp on low boost
Old 01-18-2007, 10:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
Yes,it does suck.Some cars need them,some don't.I've run into this with alot of clutches out there from all company's..
Old 01-18-2007, 10:57 PM
kookamunga's Avatar
my understanding is that many of those race clutches were never meant to be daily driven. most of the high end road race stuff will not endure many starts as they don't like to be slipped. even if thier design is rated for extreemely high specific outputs. perhaps this may be the case in many instances where we try and over clutch a street application. just a thought
Old 01-18-2007, 11:53 PM
DONAIMIAN's Avatar
Thats any clutch with a ceramic based disc, they dont like the street.
Old 01-19-2007, 03:05 PM
LS1Tech Sponsor
Slowhawk's Avatar
Thats right. Alot of people think they can buy a high HP race clutch,daily drive it and last forever. Doesn't happen.Sure some people get alot of miles but they are most likely the people that don't slip it.
Another common problem is improper installation/setup.Everybody vitches about SPEC's failing early but I've never seen them fail early and we do a ton of them on anything from DD's to seriously beat track cars. They do fail within time but it is expected with the way they are driven in those situations.
Old 01-19-2007, 04:50 PM
kookamunga's Avatar
woah! I had no idea about that. I figured it mainly applied to those non sprung metallic discs
Old 01-20-2007, 09:25 AM
black01_WS6's Avatar
SPEC told me to run the spacer as well and had similar results with my SPEC 3+. We got to it and took out the shim and everything sems fine so far- 3,000 miles on it since. I think I will only buy partsnow from sponsors that have good customer service.
