Won't go into 3rd at high RPM?
Moderator
Took my car to the track and shifted 1-2 fine. Went to go into 3rd and would not go. Tried 4th same thing. Car is fine on the road, just not at 6500RPM at the track. Tried 2 passes and the same thing both times. Still beat my friend's new 07 GT. 2nd and coast to the traps.
My car does almost the same thing, but the when i launch the clutch goes half way to the floor and stays there. The 1-2 shift is fine, just slightly delayed but the 2-3 is very slow and hard to get into gear. My slave was replaced when i replaced my clutch about 3k miles ago. Does anyone think the drill mod/master cylinder replacement will fix this problem?
Moderator
Originally Posted by davered00ss
I think it's the tranny. Should have had Don rebuild it while it was out for the clutch.
yea i am hoping mine is a tired tranny to mine has 90k miles on it
but the clutch held great and i was able to pull the wheels on the launches i just couldnt make a full pass without 3rd gear
Moderator
Originally Posted by Slowhawk
Could be burnt hydrolic fluid but it sounds like a bent/broken 3rd/4th clutch fork.I can do those in my sleep.
So how much to fix it?
Moderator
UMI short stick on a Hurst shifter. Never had this problem before. 100 or so passes on the car. Only 3 last year & 2 this year. Looks like I'm done for the year now.
We had a same prob a while back it ended up being the springs on the clutch, and would not let the clutch fully engage. But like mentioned above id check the forks.
i was having the same problem not going into third at high rpm i just got done doing the drill mod and it fixed my problem.i'm glad it worked too cause i just had the trans gone through less than 2 weeks ago,glad i don't have to pull it again.now it goes into third like a champ.
LS1TECH Sponsor
dave thats exactly what mine was doing the end of last year. new forks, sliders, syncros and a destroyed 5th gear its time for a rebuild . don knows what ya need im sure . it sucks but kinda just maintance when ya beat theses trannys with the stock forks and sliders
Ok, i had the exact same issues and just did the drill mod right now. Man!!!!!!!!!!!!!!!!!!! its the shiznit! I went and took it to 6500 in 2nd 3 times to make sure and it shifts like its sitting still. You gotta try it!
