help with clutch problems
Old 02-04-2008, 09:10 PM
razorclaw99's Avatar
Default help with clutch problems
This all started when i tryed to put the car in reverse after leaving a bank. It wouldnt go into reverse. I finally got it into 1st with enough force. 5 minutes later while driving on the highway, i tried to shift into 3rd and it wouldnt let me. It wouldnt let me go into any gear what so ever. I tried putting it into 1st with the car off and then starting it. It starts up fine and once on, it wont let me go into any other gear. It looks like the clutch doesnt disengage once engaged. Anybody know what causes this? Should i bleed the system? I checked the fluid under the hood and it was fine. (I know for a fact i didnt burn the clutch)
Old 02-04-2008, 09:36 PM
SladeX's Avatar
try a bleed, but sounds like the hydraulics went.
Old 02-04-2008, 10:04 PM
slayerized6's Avatar
change fluids, bleed hydros
Old 02-04-2008, 10:43 PM
mustang93's Avatar
DAMN already broke her... Comeon man!!! Thats from " banging those gears" like you say..
Old 02-05-2008, 12:37 AM
ok so what i do is once the problem occurs, i shut the car off. Push the clutch pedal towards me from under it. And once again i have a clutch pedal. Weird?
Old 02-05-2008, 12:44 AM
mustang93's Avatar
You have air in the system from beating on the car.. Easy fix. I had a LS1 WS6 do that to me once. Not a big deal.
Old 02-05-2008, 12:46 AM
its probably air but i havent even floored it 3 times yet? This only happened twice. Once i approach the end of 3rd from my 2-3 shift, i start to lose the clutch. How do i fix this?
Old 02-05-2008, 07:27 AM
RsSean's Avatar
It mite also be that the trans fliud is low. I found this out when my tail shaft seal was leaking it was a pain to get in gear. Come to find out that the trans fluid help it slide into gear better. Hope that helps
Old 02-05-2008, 08:45 AM
kokingSS's Avatar
my does this but only after i romp on it, its the slave cylinder going.
Old 02-05-2008, 09:09 AM
ye? dam i hope its not my slave cylinder
Old 02-05-2008, 09:50 AM
anybody know how air can get into the lines?
Old 02-05-2008, 10:32 AM
RsSean's Avatar
Low on fluid in the holding tank or the o-Ring is bad where the braid line meets the slave cylinder. Also make sure the quick connect is connected all the way
Old 02-05-2008, 02:09 PM
SPEC-01's Avatar
razor...I am kind of amazed that no one has mentioned the fact that you may be boiling the fluid. These cars are notorious for doing this as a result of the hydraulic lines passing so near the headers. As the fluid boils it aerates...thus causing air in the lines. I suggest flushing the fluid and refilling with a higher boiling point fluid. You should also make sure that the hydraulic lines are wrapped with a good heat resistent wrap. Let me know if you have any other issues and we can go from there in regards to further trouble-shooting.
Old 02-08-2008, 06:37 PM
chevyss3460's Avatar
Whenever you have problems going into reverse, try shifting in 1st gear then go to reverse and it should slide right in. It sounds like you have a hydraulic problem.
Old 02-11-2008, 01:39 AM
found out its the steel braided line (restriction)..friend had exact same problem.
