Best Of The Best
Old 06-11-2008, 09:41 PM
WS7_FORMULA's Avatar
Lightbulb Best Of The Best
well tomorrow i should be done with the whole clutch, flywheel, and cylinders upgrades...so.., i just need the t56 fluid and clutch fluid....
which is the best for the tranny???
and for the clutch?????
Old 06-12-2008, 12:47 AM
??????????? anyone please............
Old 06-12-2008, 07:40 AM
Viper's Avatar
Penzoil Synchromesh for tranny, dot 3 valvoline syntec for the clutch. My $.02.
Old 06-12-2008, 03:45 PM
LS1PHNX's Avatar
for the clutch, i think any dot 3 fluid would work just fine
Old 06-12-2008, 04:09 PM
stoverz28's Avatar
Ive heard synthetic causes the seals in a Mcleod mc to go bad. Might want to watch out if you run one.
Old 06-12-2008, 04:35 PM
Viper's Avatar
DOT4 is what kills the seals in the McLeod - I run one.
Old 06-12-2008, 05:17 PM
IS IT THIS ONE???
I WENT TO AUTOZONE AND THEY HAD THAT ONE THERE. IT SAID SYNCHROMESH AND JUST THE FRONT TAG LOOKED DIFFERENT. BUT STILL IT SAID FOR GM PART 12345349....THEN WHAT ABOUT DEXRON 3 OR 4?? WHAT EVER HAPPEND TO THAT?? IS IT BEING REPLACED NOW FOR THIS SYNCHROMESH THING?????
AND BOUT THE CLUTCH FLUID, I BOUGHT COASTAL CLUTCH FLUID...ANY GOOD??? IF NOT THEN WHERE CAN I FIND VALVOLINE DOT 3 CLUTCH FLUID??? I SAW SOMETHING SIMILAR BUT IT SAID BRAKE FLUID.......
HELP PLEASE!!!!
Old 06-12-2008, 06:43 PM
Viper's Avatar
That's the one and brake fluid IS clutch fluid. So the Valvoline brake fluid is fine.
Old 06-12-2008, 09:04 PM
but isnt brake fluid too thin compare to clutch fluid???
Old 06-12-2008, 09:34 PM
Viper's Avatar
The hydraulic clutch uses brake fluid. There's no such thing as "clutch fluid" - you'll get laughed at if you go into an auto parts shop asking for it.
Old 06-12-2008, 09:53 PM
well i got a clutch fluid... from coastal, heard good things from it :confused:
Old 06-12-2008, 10:26 PM
ChicagoTransAm's Avatar
They they just simply rebottled brake fluid and called it clutch fluid
Same schtuff...
