shortest throw shifter
Old 06-22-2008, 12:31 PM
Ironxcross's Avatar
Default shortest throw shifter
what is it?
Old 06-22-2008, 03:56 PM
Ironxcross's Avatar
someone? anyone? ?!?!?!
Old 06-22-2008, 09:36 PM
jmd
jmd's Avatar
Custom make a shifter lever (the part w/ the ball at the trans. end) that will fulcrum higher in the stick and shim the shifter body away from the tailhousing. Yeah!
Old 06-22-2008, 10:14 PM
Ironxcross's Avatar
I lack skills on that level.
Old 06-22-2008, 10:50 PM
LS184's Avatar
r u looking for just the short stick, or the whole shifter?
Old 06-23-2008, 12:04 AM
Ironxcross's Avatar
I looking for the shifter with the shortest throw. The shifter. The stick does not matter.
Old 06-23-2008, 12:09 AM
LS184's Avatar
https://ls1tech.com/forums/showthrea...short+shortest
Old 06-24-2008, 08:14 PM
98 SNAKE EATER's Avatar
If you want the shortest throw possible, get the Power Tower/LSS combo
The Power Tower has the highest pivot point of all the shifters on the market, so even though others may have a lower stick position, the actual throw of the Power Tower is still shorter
Combine that with an angled LSS and it gives you the perfect shifting position, unlike other shifters that place the **** so low in the console that it's just plain retarded
The only drawback is that it requires a bit more muscle to shift than other shifters, but only a girly man would complain about that
98 Aztek T/A WS7
70 Ram Air IV T/A
97 FZJ80 Locked
00 Lifted G16E
GhettoChopper
