New rebuild Problems
I just had the dealer ship put in new blocker ringers and synchros and my trans doesnt want to stay in third gear. When it pops out it makes a grinding noise. Any Ideas what it is? They told me My pro 5.0 is worn and needs replaced but every other gear works fine. Any input would be appreciated.
Just make sure the stops on the shifter are backed out first.
Popping out results when it's not engaged fully. Usually either the synchro keys are broken or not working, or the shift fork has worn/missing pads or has been bent.
Double check the shifter stops, then take it back to the dealer and have them rebuild if the shifter stops are not in the way.
mike
mike
I already tightened the screws, there in far enough where the shifter doesnt even touch them. They said they replaced the Synchro assembly's and all the shift fork pads. Could a worn out shifter head be causing it to not fully engage? I am planning on removing it tonight but really dont want my car to have to go back in. They took 3 and a half weeks with it to rebuild it the first time.
Transmission builders that work at dealerships are some of the stupidest builders I have ever come across . If the problem is not listed in their repair manual or all data , they have no freakin clue . I cannot tell you how many times I have personally had to go to a dealership and help either diagnose an issue or straight up fix it for them . I am not sure if they are the same with automatics but I would bet they are .
If its got issues in 3rd gear and you are 100% sure the shifter is adjusted correctly , I would say you need to replace the 3-4 shift fork as well as the 3-4 syncro keys . I always replace them even if they are not broken . If the customer cannot afford the billet keys , I still replace the stock keys with new stock keys .
