GTO Bell Housing vs. Camaro Bell Housing
Is the GTO 6-speed bell housing different from a Camaro bell housing? I cannot seem to get my LS1 starter to fit. I'm using an LQ9 engine. Am I using the wrong starter?
Please Help!!!
Please Help!!!
They are identical in every way but one, the lS2 housing has a smaller starter hole. You will most likely have to pick up an LS2 starter, I'm not sure if you could grind the housing to get it to fit.
