which red loctite/permatex for flywheel bolts?
Old 08-29-2008, 11:30 PM
squarehead's Avatar
Default which red loctite/permatex for flywheel bolts?
permatex and loctite make at least 2 types of red
1) high stength
2) high temp
which one should be used on the flywheel bolts
Old 08-30-2008, 12:46 AM
wrencher
wrencher's Avatar
The high strength should do ya just fine.
Old 08-30-2008, 09:21 AM
squarehead's Avatar
thank you,
I am leaning towards the high temp because of the heat in that area.
Here are some specs for the Permatex High Strength vs. High Temp
High Strength: breakaway tq 250 in/lbs prevail tq 275 in/lbs
High Temp : breakaway tq 200 in/lbs prevail tq 250 in/lbs
The High Temp data sheet also states it can used on flywheel bolts.
Since Permatex data sheets have cross references to GM part numbers, does anyone have the GM threadlock/sealant part number from their service manual?
Old 08-31-2008, 09:36 AM
squarehead's Avatar
more info
I found 2 different GM part numbers for thread lock for flywheel bolts
2008 info indicated 12345382 which is equivalent to Permatex blue
another source indicates 12345493 which is equivalent to Permatex Red High Temp
Old 09-01-2008, 12:04 AM
studderin's Avatar
your be fine with either
Old 09-01-2008, 12:39 AM
wrencher
wrencher's Avatar
Put all 3 on then???lol
Old 01-16-2009, 08:19 AM
KurtRardin's Avatar
I was told that GM thread sealant is the only thing I can use. Is that true? I have gobs of the loctite that I used to sell when I worked at Advance Auto.
What ever you do though... dont mix loctite with anti-seize. Some say it may tear a hole right in the universe!
Old 01-16-2009, 08:58 AM
Grifter's Avatar
Blue loctite will work fine too. Just make sure you use loctite!
Quick Reply: which red loctite/permatex for flywheel bolts?
