T56 weight
Old 09-10-2008, 05:15 AM
Pete walsh's Avatar
Default T56 weight
Does any one know the weight of a t56 gearbox including bell housing?
Thank you
Old 09-10-2008, 06:19 AM
Jon5212's Avatar
I believe its between 80-100 pounds.
Old 09-10-2008, 10:17 AM
jmm98LS1's Avatar
Closer to ~135....with all the packing & plastic tub mine was shipped in, it was almost 150lbs.
Old 09-10-2008, 10:29 AM
aNuBiS's Avatar
How about compared to the t5 trans in the v6's
Old 09-10-2008, 10:51 AM
rollinna65's Avatar
Yeah, I've always heard its around 125 lbs dry and after manhandling that thing out from under the car in a driveway I definitely believe it. Just imagine how much that thing would weigh with an iron case.
Old 09-10-2008, 10:53 AM
rollinna65's Avatar
One site I found says a t5 w/ bellhousing only weighs 87 lbs. Now I'm curious how much that 3.8 v6 weighs. Its probably heavier than the ls1.
Old 09-10-2008, 10:57 AM
thesource's Avatar
Most T5's with out the bellhousings are about 75 lbs dry . I am pretty sure the T56 with out bellhousing is around 135 dry . Tremec TKO's are around 110 dry .
aNuBiS's Avatar
From what I gather, the 3.8L is the same weight as an LS1
Old 09-10-2008, 10:48 PM
Tavarez's Avatar
Do rebuilt transmissions from rockland or RPM usually weigh more? If so by how much?
Old 09-11-2008, 09:32 AM
thesource's Avatar
The T56 with the after market gears probably does weigh a few pounds more than a stock one . I have never compared the two on a scale .
Here is a side by side comparison of the size and weight of a T56 vs. T5 .
Old 09-11-2008, 01:39 PM
rollinna65's Avatar
Looking at that t-5 I'm curious how they get the shifter far enough back to fit through the hole. Do the v6's have a remote shifter like the GTO's?
Old 09-11-2008, 01:51 PM
the_merv's Avatar
^^Have you ever seen how far back the Engine sits in one of the V6 cars..they are in there..
Do we have an actual verified weight of a T56, full of fluid without the Bell Housing?
Old 09-11-2008, 02:12 PM
rollinna65's Avatar
They must be sitting right on the firewall cause its already close as is.
Old 09-11-2008, 10:02 PM
thesource's Avatar
Thats actually a Ford Mustang T5Z . The GM version has the shifter a little further back .
Old 09-12-2008, 07:37 AM
calhoon's Avatar
The weight of a T56 is different between models but the Fcar version is 120-125Lbs. If you package it in a sturdy box you will be close to the Fed Ex limit of 150 lbs ( cheaper rates).
Old 08-08-2011, 08:57 PM
Walt Kowalski's Avatar
Just weighed a T56 COMPLETE with bellhousing, shifter and slave from VZ Commodore
The T56 was 55.7Kgs dry so about 123 lbs
Quick Reply: T56 weight
