Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Need one solid roller lifter
Old 01-23-2008, 11:15 AM
Restricted User
NBM2001z28's Avatar
Default Need one solid roller lifter
Sounds like a joke - but i'm not kidding. I lost mine for degreeing cams. I need another Kinda needs to be in ok shape, for an LS1/2/6 etc as well.
Old 01-23-2008, 11:23 AM
Retired Street Racer
Matt D's Avatar
Do you need me to pull one out off of my 454 LSX motor?
Old 01-23-2008, 11:47 AM
Bryan @ Speed Inc.'s Avatar
why not just use a light check spring instead of a solid lifter?
Old 01-23-2008, 12:24 PM
Restricted User
NBM2001z28's Avatar
Not sure, Always have used a solid lifter and so far so good. Till i lost it
Old 01-23-2008, 12:38 PM
1_bad_ss's Avatar
You could take a stock one and pop the clip off of it by the plunger. Take it apart and put small washers in it to take up all of the room, just make sure it is tight and reassemble. There's your new solid lifter
Old 01-23-2008, 12:58 PM
Restricted User
NBM2001z28's Avatar
The aluminum one or the iron one
Old 01-23-2008, 01:17 PM
i've used a spring that i bought at ACE hardware that just fit around the valve and held up the retainer. super weak, but held the weight of the valve.
the spring is accessible and only cost like, .30 haha
Old 01-23-2008, 01:18 PM
Matt D's Avatar
The iron one with the fancy orange paint on it.
Old 01-23-2008, 07:28 PM
quadd2244's Avatar
Sounds about right we all knew you were hiding something with those 11sec pass's
Old 01-24-2008, 07:53 AM
Matt D's Avatar
It's a 454 LSX motor with a 205/210 sleeper cam
Quick Reply: Need one solid roller lifter
