2jz S2000
2jz S2000
Possibly the coolest honda ever. I want to see them put it in a NSX.
http://www.youtube.com/watch?v=WirkGXYdOus&NR
it never mentions what it put down.. they'd have to spend alot more $ for the single turbo/fuel setup..
so lets see:
used s2k: 20k
2jz by these guys: 16k
big turbo/fuel setup: 10k (probably low est.)
not including the rear/tranny/clutch.
so lets see:
used s2k: 20k
the whole swap including labor is 14k
and that car is probably making 350whp on just 10lbs
and after changing the rear end, it will probably be reliable for 30lbs-(about 700whp)
they weren't completely done with the car when that video was made, it should be a beast when they're done. i would much rather have that set up than the original....
that run was only on 9psi on the stock rear end, they're going to put a silvia rear-end in it also. so they weren't trying to tear anything up. not to mention it wasn't their car to beat on.
so lets see:
used s2k: 20k
so lets see:
used s2k: 20k
I dont think I would trust those guys with $14-16 k there shop looks like a garage on there house with no lift and I really couldn't see a lot of tools around to assist in swapping motors let alone the fabrication of parts that would be needed
Originally Posted by BlakeLT1WS6
o so you cant get quality work from someone that works out of their garage?
