My poor LT
Old 12-08-2006, 03:11 PM
BigDB's Avatar
Default My poor LT
Dont really know how I blew a hole in primary 1 of my long tube but I did. I wasnt even at WOT. I thought it was the gasket that blew since I just had the headers off doing mounts but when I opened the hood to my surprise a hole. Here ya go:
Old 12-08-2006, 03:18 PM
1LoudTA's Avatar
ouch... dont run the car like that unless u want a fucked up exhaust valve
Old 12-08-2006, 03:22 PM
BigDB's Avatar
ya I know, its sitting in my garage awaiting new headers. I was hoping to just ask my dad to forget the money I owed him for christmas but nope ill be getting longtubes and more debt.
Old 12-08-2006, 05:32 PM
transAm-98's Avatar
I had the EXACT same thing happen to me. I thought something was wrong with my valvetrain until I opened the hood and got slapped in the face with exaust.
For a temporary fix I just hand rolled a really thin sheet of aluminum around it and held it on there with 2 hose clamps. It actually worked really well and didn't leak at all.
Old 12-08-2006, 05:52 PM
cws T/A's Avatar
Have the hole welded
Old 12-08-2006, 06:05 PM
BigDB's Avatar
If its welded itll just crack again. The constant heating and cooling will just do it again on such a large weld
Old 12-08-2006, 06:48 PM
cws T/A's Avatar
cut it out , add a new peice of 1 3/4 , btw what brand are those headers
Old 12-08-2006, 07:47 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Did those headers have AIR fittings on them?
Old 12-08-2006, 08:23 PM
rickyracer25's Avatar
Old 12-09-2006, 12:01 AM
BigDB's Avatar
they are flowtechs, no there was no AIR or EGR tube welded there. They are both placed on the passenger side.
Old 12-09-2006, 12:03 AM
Tainted2's Avatar
flowtechs, that explains it all right there
Old 12-09-2006, 12:42 AM
BigDB's Avatar
flowtech is the same design as hooker since holly owns both hooker and flowtech. both use 18 gauge tubing, except the super comps which use a 16 gauge.
Old 12-09-2006, 12:52 AM
BigDB's Avatar
Ok sorry, I wasnt thinking right and yes there was a tube there. That makes so much more sense. Still sucks and doesent change the fact that it broke.
Old 12-09-2006, 06:06 AM
Z28/2002's Avatar
My pacesetters did the same thing except it was on the passenger side. If you used the block-off plates that they sent with the headers then that is more than likely what caused it because that thing is heavy. The engine rocking back and forth didn't help much either ( I had the same cam in my car before it burnt to the ground )
Old 12-09-2006, 08:46 AM
ynkssws6's Avatar
time for some QTPs
Old 12-09-2006, 01:35 PM
crazyidiot4.8's Avatar
happened to my friends LT1 too, same primary. he had BBK long tubes though
