what is the point of a throttle body bypass mod?
once you do this mod, you won't have hot coolant running through your throttle body, which only heats up the intake air. you'll have a bit cooler intake charge, thus a couple extra horses.
LS1Tech Administrator
Received 1,493 Likes
Just don't expect any significant gain from this. Yes, in theory it's a good mod, but nobody has ever gained noticeable horsepower on the dyno or trap speeds at the track after doing this mod.
For $2 though, why not do it I guess.
LS1Tech Premium Sponsor
Agreed, don't expect any ET drop, but it's too cheap not to do.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The only reason I did this mod was because I switched to a FAST intake and if I remember correctly it doesn't have anything so I had to do the bypass mod. Besides it really does nothing. if you lived where it gets real cold I'm sure it would be beneficial to not do this mod
