YOU really need to see this !!!
Old 09-14-2010, 01:31 AM
stubbs4's Avatar
Default YOU really need to see this !!!
So i this probelm
AND THIS ONE
i just had a few questions that someone woulnd mind answering
1) do i have the whole kit because only one screw goes in. look below
also any tips on getting the new oil pan to fit perfectly!!!
oh an another thing this nut on the alt is stuck any ideas how to get it off?? look below
also where can i put the jack so i can jack up the engine any input would be very helpful thank you ls1tech!!!!!!
Old 09-14-2010, 02:54 AM
01ssreda4's Avatar
Hook an engine hoist to the cylinder heads or something. Don't jack on the engine at all. Bad idea
Old 09-14-2010, 03:06 AM
stubbs4's Avatar
i dont have a hoist or money for one
Old 09-14-2010, 06:51 AM
david068513's Avatar
Thumbs up
If you have to jack it, put a piece of 2x4 between the pan and the jack it helps to not dent the pan
Old 09-14-2010, 03:04 PM
Mumbles's Avatar
Okay, I'll bite...
Why is there a giant hole cut into the bottom of your oil pan?
Old 09-14-2010, 03:09 PM
Z28_LT1's Avatar
I'm guessing this:
answers this:
Originally Posted by Mumbles
Okay, I'll bite...
Old 09-14-2010, 03:14 PM
$750 L98's Avatar
Okay, I'll bite...
Air cooled mod.
Old 09-14-2010, 03:16 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I agree with Z28 LT1
Old 09-14-2010, 03:27 PM
buddha845's Avatar
its pretty impressive however it happened lol
Old 09-14-2010, 03:34 PM
djquik88's Avatar
It's to get that small piece of trash off of the pickup screen.
All jokes aside...That sucks bro..
Old 09-14-2010, 03:35 PM
stubbs4's Avatar
it doesnt matter how it happed i just need to change it !!!! LOL
its an m6 btw
i cant seem to get the motor mounts out can some of you guys spare some TIPS please
Old 09-14-2010, 03:38 PM
stubbs4's Avatar
BUMP for some help!
Old 09-14-2010, 03:40 PM
stubbs4's Avatar
also what can i do about that stuck alternator and someone explane how to pull the puller off thank you again!
Old 09-14-2010, 03:53 PM
bigbird01's Avatar
did u happen to jack the car up by the oil pan on accident?
Old 09-14-2010, 03:55 PM
Snake_Skinner's Avatar
^Really going with a yes on that one. that must be frustrating.
Old 09-14-2010, 04:13 PM
Jays_SSZ28's Avatar
Maybe he ran over a jack laying in the road the other night.
Old 09-14-2010, 04:16 PM
DVS99TRANS's Avatar
I had the same problem with the alternator lug. I cut the cable at the terminal, removed the bolt on the alternator, got the old lug off, stripped the cable and recrimped a new terminal on it. Then re-thread the bolt into the alt and tighten the new terminal on. That is the easiest way to do it without making to much of a headache. Just make sure you put a terminal about the same size on. You can buy terminal lug kits for cheap at Autozone, Walmart, Advanced Auto, etc... They are cheap too. might take 10-15 minutes truthfully.
*It can be alot easier with the alternator removed from the bracket but can be a headache getting the alternator back in. When I did this to mine I was in the middle of an engine swap so it was not on the car when I did this fix.
Oil pan*- when you go to put the new oil pan on, put a small bead of RTV going all the way around with a new gasket and follow the proper torque to a "T". The rear long bolts on the oil pan are very weak in my opinion and have snapped them before. i would buy 2 new rear oilpan bolts if I where you and "Not reuse the old ones". The oilpan itself is not hard to line back up fella. Sorry for your bad luck and hope things work out bro.
Old 09-14-2010, 04:26 PM
whtrashferrari's Avatar
Default lol
Okay, I'll bite...
LOL thats great !!!
nothing like getting to the point
Old 09-14-2010, 06:17 PM
OMGWTFBODY's Avatar
Be careful. It looks like you've scraped your K-Member on something.
Old 09-14-2010, 07:48 PM
Arc00TA's Avatar
I had the same problem with my alternator, but it was bad and I was replacing it with a 145 amp truck alt. I beat the **** out of it with my mini sledge until the plastic was all broke and I could put a wrench on the stud to hold it still.
