Spark plugs and wires
Old 10-09-2010, 10:02 PM
DukesOfHazard's Avatar
Default Spark plugs and wires
Just finished installing my msd 8.5 superconductors and Ngk tr55's. Only took about 4 hours (first time ever doing plugs an wires in a car literally) bandaids are amazing lol. Tried getting the #8 plug from the top for about 20 minutes and finally got fed up and tried from the bottom. Got it all finally and man does the car feel better. Old plugs weren't TOO horribly bad, but they definitely needed it. I'm sure the wires helped too :-)
Old 10-09-2010, 10:33 PM
bongva's Avatar
cool i guess?
i can get all my plugs from the top of my car.
Old 10-09-2010, 10:53 PM
garygnu's Avatar
test your old wires resistance compared to your new wires resistance.check plug resistance before and after swap.
Old 10-10-2010, 04:00 AM
myk
myk's Avatar
I don't see how anyone gets to the plugs from underneath, but that's just me I guess. Cheers!
Old 10-10-2010, 02:38 PM
omarrakeen's Avatar
^X2 with the log tubes on it seems impossible! to the OP i changed wires only my TR6s are sitting in my car...too lazy to do it lol..gd work
Old 10-10-2010, 04:46 PM
To be honest, this seems like a feat to me because I have only wrenched on a car in the most minute ways, doing oil, air and fuel filter changes is about the extent of it. So, for me, changing plugs and wires for a first time in this car was pretty gratifying. I think if someone could post a pic next time they do a plug and wire install with the correct angle of the attachment for the last plug I think it would help people a lot. I have probably seen it, I just don't remember lol.
Old 10-12-2010, 04:02 AM
cowboysfan's Avatar
I find it to b quicker when I remove the coil packs. on the passenger side I dont re-install the last one in the back, that was a pita to remove, so out it stays... all r done from the top.....
Old 10-12-2010, 08:14 PM
I actually did loosen the coil packs, I just didn't take them all the way out. I just couldn't seem to get the right angle to get the plug to turn. Didn't want to break it so I just decided to go ahead and climb under the car since I already had the jack and jackstands handy.
Old 10-12-2010, 11:15 PM
whitdog54's Avatar
congrats! how many miles did you have on stock plugs and wires?
Old 10-13-2010, 07:37 AM
Element's Avatar
Werd...I did all of mine, even #8, last time from the top without touching the coil packs at all. Hardest part was making sure the plug wires were properly seated.
Old 10-13-2010, 09:52 AM
JM0523's Avatar
Yeah i bought some TR 55's about 6 months ago and now im glad i was too lazy to put them in because i just traded them off on some Autolite 605's to go with my new nitrous setup.
Old 10-15-2010, 07:40 PM
samson_420's Avatar
The 1st time I did my plugs and wires I was expecting the worst. . . . It really wasn't all that bad. About 2 hours, a dozen cat claw like scratches on my arms and enough swearing to make a sailor say WTF, I got mine done. . . . LMAO
Old 10-16-2010, 08:01 AM
zracer323's Avatar
This is how I do it. Makes everything really easy to get to.
Old 10-18-2010, 10:48 PM
NVR_SPDS's Avatar
I do all 8 from the top.. doesnt take long any more, since ive done it so many times on a few different cars. I pull the coil packs on the pass side, because i got some god damn gorilla arms, and need the room.
The best way i have found to get on all the plugs is to put the spark plug socket on the spark plug, then use the correct socket to fit the hex on the back side of it.
