Car just hit 205,000 miles...
The car is my dd and I want to be proactive here and replace things that COULD/WILL fail causing me to be out. I know its impossible to fix everything internally without doing a total rebuild, which I dont have quite that much cash to do. I have heard possibly changing the oil pump, timing chain etc. Just kind of wanting to replace things along the way. any suggestions on what to do to keep this thing running for another couple years at least? I have changed the plugs/wires and change the oil every 3000 miles and have a small oil leak with a few drips in the driveway every night. loses about 1/2 quart every oil change. No burning oil. Thanks in advance!
Justin
Justin
Things that go are things that go on any car around that mileage...
-Fuel Pump
-Battery
-Oil Pump
-Water Pump
-Power Steering pump
-Alternator
-Thermostat
Make sure you have changed your rear diff fluid recently and coolant, tranny fluid. Make sure your maf is clean. May want to sea foam at this point.
-Fuel Pump
-Battery
-Oil Pump
-Water Pump
-Alternator
-Thermostat
do a oil pump and ls2 timing chain.install new valve springs and get some low mileage stock rocker arms.maybe install a new pcv valve.go to ls1howto.com for pics and instructions.you can get these parts at TSP website.
my chassis has 118k but the ls6 and tranny have less then 600/10,000 respectivley.
if you just keep up with routine maintenance you should be fine assuming you dont beat the hell out of it.
