getting the car side ways
Quick question, my 02 a4 ws6 will burnout, it will light the tires up like crazy from a stoplight and when I turn left she will drift out and scream like no other...but when I turn right and punch it, it takes its time and wont want to break loose and drift out. Does any one have a clue why? Am I the only one who has this problem or just me?
If you want to swing out when turning right with a Torsen posi, what I have found works best is go for a slightly more wide turn. If you go for a sharp 90 and hit it, then it will one wheel peel for a minute before it catches (then you will probably have already completed the turn). If you want to swing wide during the turn, don't throw so much weight when you turn. Go easy with the steering wheel, get em spinning and let the car come around. You need room to pull this off obviously.
