Going to the drag strip, need some tips
This September a friend of mine and I are going to the drag strip. He's a bit older than me and has taken many cars to the drag strip, but never this one. He has a 2009 Pontiac G8 GT, which he always says will crush my car. I have never been to a drag strip before, so I was looking for tips and advice on how I can beat him, and if I can.
I will hopefully be putting the SLP Lid on my car before September, and I already have the SLP LM1 Cat-back, should get a bit of HP out of those two mods. My car is also an A4, so launching tips would be helpful. I also plan on removing ALL extra weight from my car, the spare tire, the jack, all the crap in the trunk, anything of weight out of the glove box. I'm also running royal purple synthetic motor oil. Appreciate all the help and insight I can get.
What a dick...lmao
What I do is go around the water box and line yourself up,then hit the brake and accelerate just enough to get any debris off the tires.(roll thru the burnout so your not in the same spot( When you stage try to barely break the beam(this will give you 12" or so of space for the launch). When the last yellow light comes on floor it and you should tree him,if not practice makes perfect.
my stall converter took nearly a whole second off my 1/4 mile time.
go to the track. fill out your tech card. find a spot to pit. instead of going up to race right away, stand around and watch what others do as to not make a total *** out of yourself
Reaction time is key. If you really want to beat him then you should cheat... Perhaps you should honk your horn just before the lights drop to take his attention off the tree. . Better yet, fill up his trunk with your old dumbells, golf clubs etc...
Honestly I think it should be a close race... If he's stock. I think Stock G8's are mid 13 cars but I could be wrong.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
Good read for a first timer - http://www.modernmusclecars.net/foru...hp?do=drbasics
How's Meridian? Was stationed there for 4 years at NAS.
you are 100% correct...if this guy does this he wont' be able to **** it up ..he will have traction and leave alot harder..you reading this OP??..how bad do you want to beat your freind??..if it's bad enough then go take out a 1,500 loan..buy a 3000k-3800k stall (my personal opinion for a street car) for around 500 bucks or find one on here for cheaper...and buy some MT drag radials ..if you are'nt mechanicly inclined you will pay about 300 on average to get the stall installed ..but with those 2 things..you car will be a beast off the line..you should run into the high 12's somewhere just those alone...i dropped 5 tenths with my 3K stall..and that was on a car that already was running 11's..catch my drift?
stall and tires is the best advice. do your burnout in first, shift to second. pull forward and barely light the first bulb. wait for him to light both of his. then inch forward barely so you can keep your foot of launch space. makes a world of difference. throw it in drive and flash the converter. stay on the wood til you get through the whole 1320. lots of guys let up early. have a blast.
btw remember that staging can be where the race is won. sometimes ill wait for the other guy to do his burnout before i even start mine. it throws people off. and the honking your horn trick is sinister but hilarious hahah
if the G8 is stock then it's pretty much gona be a drivers race...yes there is a 70 or so RWHP difference between the two cars...but there is also a 500lb(give or take) weight difference.to the OP>>..if he does beat you, it should'nt be by much..and vice versa...your car is'nt gona destroy his in a race unless he spins bad or something like that....it should be a fairly close race..get the launch down
To everyone's questions about the G8 GT. It's the L76, a 6.0 V8 making 361HP and about 380 lb/ft of torque. Car weighs in a little over 4,000 lbs, and it is completely stock, no filter, no nothing. Only mod of any kind is synthetic motor oil. I have never raced a G8 GT before, or him on the street, but from what I do know, that for a four door sedan it is a very quick and peppy car. The LS3 is what the G8 GXP has, a 6.2 V8 putting out 415HP, very similar to what the new Camaro SS has. His car has a 6 speed auto. My car weighs around 3,500 lbs, as most of you should know. I'm hoping that 500 lbs of weight should give me a nice edge. Remains to be seen, I will be posting pictures and videos in September after the race.
The poster up top was wrong a G8 GT only has a LS2 ENGINE not a ls3 the GXP has the ls3. so he has about 50 HP on you stock for stock, this is not entirely that hard to overcome and beat him in a quarter. getting the best launch is the key however because 50 hp will make a difference on the last half of the track.
My car mostly stock runs just as fast as my buddys 6.0 GTO which is the same ls2 engine and I am sure the G8 weighs more than that. It will be a fun race for sure but if he races all the time he is going to be touph to beat with your stock car. but if you really want to smoke him save up for a stall converter and install it before september
