How do you get old rusty Nuts/Bolts out W/o stripping them?
PB BLASTER. and a torch. HEAT IS YOUR BEST FRIEND!!! heat evenly til it begins to glow........I use a little blow torch with MAPP Gas.
also the heat actually blows some of the rust off the bolts. Nuts that wouldnt budge even using my Matco mt1769 impact, which has 600lbft instantaneous torque and 1000 lbft after several seconds, come off like butter after THOROUGHLY heating.
PB blaster. When i did the headers on my 84 Z28 I went outside for about 2 weeks and sprayed them. Then when i went to do the headers, got every bolt out with none breaking and they came out fairly easily too.
Probably was a bit of overkill but i'd rather have done that then deal with a broken bolt.
LS1Tech Administrator
Received 1,493 Likes
Another vote for PB Blaster. Think of it like WD40 on steriods.
Moderator
If it won't back out, turn it in until you feel it yield.
Then you've got the rust broken and have a good
chance of working it out, and you won't have rounded
off the important corners trying to break it loose.
I agree with everyone else, heat is by far the best way. And make sure you get MAP gas torch, not propane. MAP will heat it much faster.
